-   purchased a sandisk 4g micro sd card. can't get it to work. tried to download music and device says it is full.-   joneill718
Jul 07, 2008
-   I was told by SanDisk tech support that if my unit (e250) was version 1 then 2gb was max for SD card. If it is ver. 2 (noted on the back I'm told) then it will support the 4gb.-   Guest
Mar 18, 2008
-   I've been using the e250 (2gb) with a 2gb microsd with success so thought I'd try the 4gb. Bought a Kingston 4gb. Windows XP sees it but cannot format it. Windows Media Player doesn't acknowledge it's existence. Using the MSC USB mode. Any ideas?-   tdillons
Feb 29, 2008
-   i have a 4GB micro SD CARD and my e250 seems not to be able to use it. Is there a solution for this? Or I just have to forget about it ?
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 13, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Not the E250, but the E260. The device seems unable to utilize the extra memory for music.A scam. Buy a ZEN.
I have a Sansa e250 with a Lexar 4 gig micro sd. And I don't have any problems at all. I've had videos on it and music. Works just fine...I want a 8 gig micro sd ..Will get one real soon.....
Well, how can i reset my sansa e260? i tried that to solve my problem where it was stuck on the...
(More)
Well, how can i reset my sansa e260? i tried that to solve my problem where it was stuck on the "refreshing database" screen, and I tried for the solution but the situation is same and it's not working. Should I just return it to the SanDisk Company or get it repaired?
