Question about Palm Tungsten T5 Handheld
On/off switch The on/off switch at the top of my palm T5 is difficult to work. Sometimes I have to press it hard several time to get it to turn on. I'm afraid soon it will stop working altogether. HELP!
  • Mulenga Jan 31, 2008
    My T5 on/off switch stopped working a month after I puchased it. I want to do a hard reset but need the switch. How else can I reset?
  • Anonymous Jan 19, 2009
    Yes, I also have trouble turning on/off my T5.
I am pretty sure this is a software problem, not a switch problem. The T5 is the Ford Edsel of the Palm range, with many unsolved bugs. I fixed this problem by using shortcut for ON and OFF.
Switch ON:
Use one of the 4 application buttons. The default house button opens the Palm at the menu, but you can change any of the buttons in
Preferences > Personal Buttons
to open whatever application is convenient.
Switch OFF
Preferences > Other Offstroke
check Enabled, and Pen Stroke or Screen Tap (or both), and then select the gesture that will turn off the Palm. I use "Screen Tap in top left corner" to turn off.
It's not a real solution, just a workaround. I also flushed and reset the T5 and reloaded from backup, and the problem went away for a while, then came back. It gradually takes longer and longer to switch on and off. There is some bug in the OS, but Palm doesn't seem to care about it.
Posted on Oct 09, 2009
Seems to be a common problem with Palm. It happened to my T5 and several others.
Posted on Jan 25, 2008
White Palm Centro freezes randomly. Doesn't respond to input
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
How do you flash the rom on tungsten t5
Sir now you have to upgrade the software of your phone
Jun 01, 2009 | Palm Tungsten T5 Handheld
The palm centro say phone is off
press two soft keys while switching it on and reset the phone to default
May 17, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
pls try these steps first,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
otherwise update rom from here,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Mar 03, 2009 | Palm Tungsten T5 Handheld
Fatal alert
This is a common problem with the Tungsten line, You can try doing a hard reset. This worked for my E2. If that doesn't work, the battery must be removed for a few hours. Although it still may not work after the battery removal.
** To preform a hard reset, hold down the power button, and push the reset button on the back of the unit. The top of your stylus unscrews to expose a "plastic pin" for this purpose. Keep holding down the reset button while the unit reboots. You should see a palm screen displayed while it restarts, let go of the power button and follow the instructions. Pressing up on the pad ring should erase all data.
Feb 20, 2009 | Palm Tungsten T5 - Multilingual Handheld
Centro GSM unresponsive at times
My Centro doesn't respond ("freeze") on incoming calls up to 10 times a day. The "answer" button (on the screen) and green "send" button (next to "phone") block and it is impossible to accept the incoming calls. It is necessary to perform a soft reset to solve the problem temporary. Even after hard reset the situation is the same. This is very frustrating for a new device. Sometimes, frequent callibration of the screen from the "Preferences" menue delays the freezing effect. AFAIK the problem is software-related, considering the recovery after reset. Is there any update on the palm support page / forums, related to the problem? I couldn't find any. From time to time, there is onother problem I experienced - from the contact menu it is difficult to dial the selected number. Sometimes it is necessary to press “dial” several times resulting in significant delay.
Mar 19, 2008 | Palm Treo 500 Centro
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Interrupted update - jammed
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Apr 17, 2006 | Palm Tungsten T5 Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
150 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
