JD X595 4x4 mower - PTO was cutting out intermittently, so cleaned all the switch and connector contacts under the dash. Now it will start OK, BUT, as soon as the brake is released, the motor cuts out. Also, with foot on brake and engaging PTO, motor dies - Panel lights now show Charge light on when engine is running which wasn't happening before. Used to also get solenoid click noise when ignition turned on motor not running and pulling on the PTO switch, now there is no sound of activation !! I haven't mixed the connectors while cleaning them, did one at a time. Cleaned and CRC'd the seat switch too. This is a total mystery, since nothing was changed. ** I disconnected the battery BEFORE disconnecting and cleaning the connectors ** Any help would be greatly appreciated.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
