No reset button. You have 2 options. First locate and remove radio fuses, wait a minute or two and reinstall fuses. Second you can remove the radio and pull the wiring harness from it and again wait a minute or two and plug back in.
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Cut the power to it completely, so if its on a breaker, press the test button on that breaker. Wait 3 minutes and put power back on. Has it cleared the problem?
its usually done with the switch to off and then hit the set button while pressing the fast forward button for the hour and then the seek button for minutes then repress set
check wires under ipm or fuse block and in wheel wells. wiggle them while having someone watch radio. thats if radio completely shuts off otherwise the radios prob junk like the rest of the car.
To set the clock on the pioneer DEH-P2900MP Detachable face radio/CD/MP3 Player, follow the following steps in order.
Press the large round knob and hold for 5+ seconds to tuen the radio "off".
Once the radio is off press and hold down the large round knob 5+ seconds to enter clock set mode. (Note: You must hold the knob down otherwise you will just turn the radio back on.)
Now choose the < or > button next to the large knob to toggle between hours and minutes. Rotate the knob to adjust the digits.
When complete press the radio/sat button @ the top right of the stereo face.
When finished, quickly press and release the large knob again to turn the radio back on.
