Question about LaCie 301103U 500 GB USB 2.0 Hard Drive
I can't download my external hard drive
I do not have an owncers manu---------------------------it says consult section 3.1 Using the LaCie Drive in the CaCie User's Manua located on the LaCie Storage Untilites CD-Rom
I don't have an owners Manual!!!!!!----------------------I cannot install my program---------------------------Please sent Manual to
102-2354 Brethour Rd, Sidney BC Canada V8L 2A5
Thank You-----------------------Marianne Clayton
  • 244 Answers
Re: I can't download my external hard drive
Try to contact this information by clicking the link below
Rate me solved if you like my solution.
Best regards,
Posted on Nov 13, 2007
0 characters
3 Points
How to recover password from LaCie 1TB Rikiki USB 3.0 Portable Hard Drive
ga naar and probeer
Support & Downloads
Frequently Asked Questions pfp.gif Printer Friendly
Configure Your Drive Using the NAS Administration Page
Accessing The NAS Administration Page
    There are two ways of accessing the NAS Administration page, Using the IP Configurator Wizard, and Using the Browser.Using the IP Configurator Wizard
May 04, 2014 | LaCie 2big Quadra 3 TB Spare Drive3 TB...
External Hard drive
Go here and choose your Lacie external hard drive model:
Support Downloads
Then click the Backup Assistant link to download the setup program.
Mar 05, 2014 | Hard Drives
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
How do I put my downloaded movies into Lacie hard drive 160
if its on a flash or C drive....... go to my computer open the folder with the movie(s).....go back to start my computer open the external hard drive (where you are going to put the movie)..... now copy and paste or click and drag from (flash or C) to external......what ever software you are using to download the movie(s) you can also change the download location to the external (now you will download directly to external)
Jan 23, 2011 | LaCie (300728U) 250 GB Hard Drive
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie d2 external drive
you may need to get a new driver for that lacie from their website..
support downloads, model o/s
Mar 01, 2008 | Hard Drives
Lacie lost evrything and is now clicking
Not without a clean sterile environment. Exposing the drive to room temperture and environment can damage the internal platters. i am willing to bet it the drive as well, but the clicking sounds like a bad drive arm, and continual attempts to use it may make the drive arm tear into the platters.
Oct 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie 301103U 500 GB USB 2.0 Hard Drive Logo
85 people viewed this question
Top LaCie Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a LaCie Hard Drive Expert? Answer questions, earn points and help others
