Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Water leaking onto the floor
I have a two year old kenmore side by side fridge freezer which I bought in France, where I live. There is water leaking out onto the floor at the front of the fridge. I read that it might be a frozen pipe....could you tell me what to do and how I would go about defrosting the pipe, if that is the cause.
  • 3 more comments
  • FredSeidell Nov 13, 2007
    We have a Whilpool 26.1 Cf unit that does the same thing ie: pool water on the floor usually at night.
  • dlind Nov 13, 2007
    Mine is turned off, but water is still leaking out of front bottom.
  • Elodie Nov 16, 2007
    Thank you for your help. I found the condensate pan full of water...which I managed to empty...checked the pipe and so far there has been no water coming out. But I need to give it 24 hours....thank you.
  • Anonymous Feb 09, 2009
    whirlpoolED22DW water leaking on freezer side on floor
  • Anonymous Mar 21, 2014
    Hopefully somthing simple
  • 288 Answers
You have a condensate line plugged up. So when the defrost cycle melts the ice from the freezer coil, it drains down to the condensate pan underneath the fridge via a tube (frozen pipe). Find the pan underneath the fridge, get the pipe that ends up at the pan and blow air through it. compressed air works the best, but lung power has worked for me in the past. After the clog is passed, there should be no back pressure. If the air doesn't work. You may have an ice blockage. You can try looking for the block, or turn the unit off, and then blow air after the ice has melted.
Posted on Nov 13, 2007
  • Rob Luna
    Rob Luna Nov 13, 2007
    This is your problem FredSeidell too. dlind, yours shouldn't leak unless you have an ice maker or something leaking.
  • Rob Luna
    Rob Luna Nov 30, 2007
    Hi guys, sorry it took so long to reply, I have had some computer problems. Both of you have some sort of drainage problems extending from when the freezer defrosts. It is simply a channeling of melted ice from the freezer to the collection pan underneath. And it is almost always solved with the tedious job of following the drain path and finding the blockage or leak. On the problem with dlind, it is possible you have an old fridge with no defrost system, or it is not working. causing ice to build up anyway.
Kenmore freezer is leaking water onto the floor
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jul 19, 2011 | Kenmore Side by Side Refrigerator
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Water Leaking - Freezer
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
Apr 18, 2009 | Frigidaire FRS26R4A Side by Side...
Water runs out of freezer door overnight ,at times
Have a look at this link:
or this one:
Apr 17, 2009 | Westinghouse Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
258 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
