The maximum number of remaining shots that the display can show is 999. If the memory card has space for more than 999 pictures, the number will stay at 999 till less than 999 remain and it will start counting down from there.
When I try to view images on a tv the connection in the camera does not hold and the image does not...
(More)
When I try to view images on a tv the connection in the camera does not hold and the image does not stay. When I move the connection to a better connection and hold it the picture will stay if I put pressure on the the camera connection. Canon 30D
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly...
(More)
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly (running water no longer looks "frozen")...any ideas?
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or...
(More)
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or less) OK, so I figure the flash metering does not rely on the same mechanism. Anyone got a clue on how to get to the AE sensor? The location pepeik posted (thanks for that!) does not exactly suggest a way of getting there.
