2006 Chevrolet Uplander Logo
Posted on Jul 09, 2009
2007 Chevy Uplander Rear Overhead A/C Vents Won't Work
I have a 2007 Chevy Uplander and The rear a/c floor vents work fine, but no air will come from the overhead vents. All of the air is just coming from the bottom - no matter where the ventilation position selector is set. All of the front vents are working fine. It's just the back overhead vents that won't work!
Dean Stewart
Level 1:
  • Contributor 49 Answers
  • Posted on Jun 29, 2018
Dean Stewart
Contributor
Level 1:
Answers
49
Questions
6
Helped
46651
Points
81
CB
Did you ever get an answer about the overhead vents on your uplander??
Dean
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4247
Points
17
Have you checked the Aux switch near the bottom of the center control console.
There should be a knob with: Aux, Off, 1, 2, 3. This is the switch for the rear AC blower.
If the driver wants to control the rear AC, use the 1, 2, 3 settings.
If you put it on Aux, Than the rear AC is controlled by the passenger in the back seat using the extra controls located on the Overhead DVD player. (The front AC must be on the rear to work)
No air blowing vents
under the dash, looks like it comes right out the bottom:
Air comes out of rear floor vents but not out of rear head vents
yes, switch for the vents are switched towards floor. remove compartment box so you can easily see switch cable
Buick terraza rear ceiling vents wont blow air
No good answer here.... A Terazza has a different type of system and this problem is very common for this model.
Any answers at all for the Terazza or Uplander??
My Uplander has the same issue...No Blocked vents. Just no air out top vents. Bottom discharge only.
2answers
Rear ceiling vents are not blowing air on tahoe
I have replaced everything from the little fuses to the mega fuse to the actuator and resistor and tested the blower and still nothing please help me
Passenger side heat doesn't work in my 2007 Dodge Grand Caravan. There is no heat, only cold air, coming from the dash, floor, & defrost vents. There are dual temp controls for the driver &...
I really can't be sure off hand, but what you wrote looks like the control valves are sticking(these flaps allow air to go different directions at the vents). its located at the heater core(towards the left side of the heater core) under the plastic just under the dash. you can manually move them, encase they are stuck, they do stick sometimes. while checking the vent doors, make sure your vacuum lines are connected. also check to make sure your vent hoses are tight. I hope this helps
2helpful
My 2007 chevy uplander blows heat only in the rear. the vents in front blow only cold air. what is the problem?
do you have the heat on up front there two seperate units check to make sure you have it on the proper setting up front
5helpful
3answers
2004 Ford Expedition XLT, front blend door actuator
Hope I was avle to help, glad you up and going.
3helpful
No air flow through 4 top rear vents
Don't worry, it's designed that way. The owner's manual is pretty unclear about this. But the heated air only comes out the floor vents underneath the front seats and the "heat vents" at the forward and side of the rear A/C compartment near the floor. The cooled or vent air flows from the overhead vents.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
