Question about Iomega Predator CD-RW Burner
Need power can someone pleeeezzzze tell me the power schematic to this thang . I 'preciate it
Will Iomega tell me where to buy the power supply in Texas? I will only buy the OEM charger.
My current Email is
Posted on Jan 30, 2008
Throttle linkage diagram
maybe someone took off the linkage cable what you need here is
to find a schematic of your unit and that should tell you where everything goes on the unit .you should be able to download a
schematic from the web!
Nov 09, 2013 | Garden
You can try contacting someone on Compaq's support site, but they are likely to tell you they wont give that information to you because it's too dangerous to work on the internals power supplies. I realize this particular model is very expensive, but you could end up killing yourself if you touch the wrong part inside a power supply, and that's no joke.
May 28, 2012 | Compaq 480W Redundant Power Supply...
The igniter glow bar gets bright and hot on the first burn in the drying cycle, however on subsequent urns it doesn't glow bright or long enough to ignite. What's up?
The ignitor is either going to be good or bad. If it fires off it is fine and if it is shutting down then the flame sensor is also working. That tells me your coils are weak and old.
Here is how it works and why I believe you need to get new coils: When the dryer is cool first thing in the morning the initial start up the fuse and control besidethemobilian_2632.jpg
it allow power to the gas assembly, the flame detector/sensor allows power to get to the ignitor and it begins to glow. 1800 degrees is what that baby puts out and at that point the flame sensor bi-metal bends and shuts down the ignitor. The holding coil and secondary coil will then have enough power partially because the ignitor is off and partially because the ignitor is now acting as a thermocouple. If for some reason the gas did not ignite then the ignitor would cool down and shut off the gas. themobilian_2633.jpg
When the temp inside the drum gets to 160f that control beside the fuse shuts off the gas assembly, IF it don't shut down the gas then that fuse melts and shuts down the power to the gas assembly but it doe not shut down the dryer. The fuse is good though because you are getting power to the gas assembly AND the gas assembly is shutting down at 160f. The dryer keeps a tumbling around till the temp in the drum drops to 105f at that time the dryer wants another blast of hot air, trouble is the coils have gotten hot now, the ignitor is doing its thang, the flame sensor is doing its thang, the control is doing its thang. The only thing that ain't happening now is the coils ain't allowing gas to come out. Replace the coils and party on! More here
Jul 18, 2011 | Kenmore 400 6942 Dryer
Rca 42 in lcd it shuts off 5 sec after being turned on
This could be a power supply problem, these tv's use a series of switching mode power supplies usually mounted in the same circuit board , the light flashing is an indicator that this is the problem, but these boards are expensive so you may want to get the tv looked at before anything else. You do not mention if the sound remains in your description of the symptom, but just in case it does then a back light inverter could be at fault. hope this helps. thanks for leaving you feed back.
Aug 27, 2009 | RCA L42WD22 42 in. LCD Television
There is no generic Horizontal Transistor for all Sony Televisions. Having repaired many different tyupes of sets over the years, the only thing that will help you is a set of schematics, and the model numbers on the transistor. You will need the schematics to find/check the other components in the display circuit that may also be bad. Very rarely did I just need to replace a HT without other power supply components as well.
Nowadays, it really does not pay to bother opening most CRT sets anymore. If you can get the schematics, you usually spend $25-$35 just on those, before you get into the actual repair.
May 22, 2009 | Sony Televison & Video
2001 olds aurora keeps overheating!!
My car keeps on overheating only on the highway when i reach bout 65 or 70 mph. it does fine all around town i can drive the thing all day around town non-stop, but when i hit the open road it gets hot tells me. hot turn ac off let engine idle...anyone knows the question to that let me know via email i would really appreciate the advise or someone who knows what hell prob is.. preciate it...
Dec 30, 2008 | 2001 Oldsmobile Aurora
So you need a copy of the PSP manual, well I found this link for you so that you can view the a electronic copy of the PSP manual, here is the link:
Check this out and I hope this helps!
Peace! :)
Oct 20, 2008 | Sony PlayStation Portable (PSP) Console
Emerson EWC27T3
Your vertical coupling capacitor is going bad, without a schematic you don't know which cap this is. Might I suggest that you get a schematic from the vendor or from one of the site on the web that carry schematics. To fix this problem you need to know which cap is the vertical coupling capacitor.
Sep 08, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Iomega Predator CD-RW Burner Logo
66 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
