Hire an electrician. Outside lights on house?? 20amp sounds like a breaker, not just a switch, otherwise why do you need a 20 amp switch for 2 outside lights? If you insist on doing it yourself be sure breaker you are working with is off. You need to know what you are doing. The question you ask says to me you don't know what you're doing. Electricity can Kill.
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
SOURCE: I have a live 2-wire line that used to be
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
SOURCE: I have a Leviton single
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
