Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
What does F5 mean?
Model 66595014100, Error code F5
2 Suggested Answers
SOURCE:
joneapelcede
  • 41 Answers
SOURCE: Kenmore model 790.96113403 F5 error code
This same thing happened to our circa 1995 kenmore limited. It would flash the F5 code 30 seconds after I tried to use any oven function. I reset the the board by cutting the power and turning it back on. It lasted for another 6-8 mos. and then I ended up replacing the main control with a new one that I got off ebay for $45.00.
Posted on Nov 01, 2012
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Bravos XL F5 error
Here is a link to the error codes for your machine. There are several F5 error codes. F5 E4 Lid not opened between cycles F5 E3 Lid unlock fault F5 E2 Lid lock fault F5 E1
Lid switch fault
Oct 31, 2017 | Washing Machines
I am trying to find a replacement part for a 24 Maytag Wall Oven, model CWG3100AAB. I am getting an F5 code, and I believe that means it is the ERC electronic control board.
Single/Double Wall Oven - Error Code/Message - F5 Error ...
www.maytag.com/...wall-oven...code...f5...code-f5-e0/PH7028/
MaytagHave a Maytag product question? Maytag's product help articles give answers to your frequently asked questions (FAQs).
Sep 30, 2015 | Maytag CWG3100AAB Wall Oven gas
I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
Jan 22, 2015 | Kenmore Refrigerators
What does error code f5 mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Read more: http://forum.appliancepartspros.com/washer-repair/244131-error-code-f5-model-11045087404-kenmore-elite-residential-washer.html#ixzz34ySdUUeZ
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
F5
Hi, F5: Outdoor discharge sensor open or short circuit.
Sharp error codes
Air Conditioning Fault Codes
Mar 04, 2014 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Error code f5
There is no error code F5. Could you mean 05? That is a flash error
Feb 12, 2013 | Canon Cameras
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
70 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
