Casio FX-115ES Scientific Calculator Logo
A
Anonymous Posted on Mar 05, 2015
How do I get to the "i" for an irrational number on the button ENG
Lonewolf
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 06, 2015
Lonewolf
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
13364
Points
25
On your Casio FX-115ES, first click the "Mode" button until you find CMPLX; next, click on that. You are now in Complex mode.
Now you are able to access the "i" button by first using your Shift button.
ka4iup
Level 3:
  • Casio Master 4,062 Answers
  • Posted on Mar 05, 2015
ka4iup
Casio Master
Level 3:
Answers
4062
Questions
0
Helped
1096508
Points
51404
Page E-3 of the manual. Press the ALPHA key and then the key to input the applicable variable, constant, or symbol.
You can download the manual from here: http://support.casio.com/storage/en/manual/pdf/EN/004/fx-115_991ES_PLUS_C_EN.pdf
What formulas contain both a rational number and an irrational number
The best known irrational number is Pi, so, any formula with that in it it, like the formula for
circumference of a circle - Pi * D
area of a circle - Pi * R^2
volume of a sphere - 4/3 * Pi * R^3
Here D and R should be rational numbers, eg integers, to meet your definition.
2answers
Is 2.33 a rational number or irrational?
It's a rational number since it can be represented as a ratio of two whole number, in this case 233 and 100.
Some irrational number are rational numbers
False. A number is either rational or irrational; it cannot be both.
Irrational number
Unfortunately, you can't. The TI-84 has a limited ability to work with fractions but it won't work with irrational numbers.
What is a irrational number called
There are a lot of irrational numbers. In fact there're an infinite number of them. One is called "pi". Another is called "e". Another is the square root of two. Do you have a particular one in mind?
Mar 28, 2013 • Cell Phones
2helpful
Example of rational and irrational set of numbers chart
You're looking for a website with examples of rational and irrational numbers? Here's an extensive one:
  1. Rational: Link
  2. Irrational: Link
Or are you just asking for a few examples?
  1. Rational: 5, 2/4, -34
  2. Irrational: ?2, ?
Hope this helps!
How do I convert any decimal into a fraction?? ex: sin45 is 0.8509035245 (press which buttons to make a fraction)
Not all decimal representations have equivalent fractions. Take pi. Its approximate value as given by the Casio FX9750II is 3.141592654. This is just an approximation because the string of decimal digits in pi has no end. It continues . Such a number that cannot be represented by a ratio of two integers is not rational, not a fraction. It is called irrational.Other such numbers are ?2, ?3,?5, e the base of natural logarithms.
As a matter of principle, if a number is called irrational, it is because it is not rational (not a fraction), and it makes no sense to try to cast it into fraction form.
However, if you truncate an irrational number so as to keep only a finite number of decimal digits, then that truncated number can be represented by a fraction, but qualitatively speaking, it is not the original irrational number.
Thus if you decide to use 3.141500000000000000....0 as an approximate value of pi then you write
3.1415=31415/10000 and the calculator will convert it to the mixed fraction 3u283u2000. To effect this conversion, you press the [FD] key to the right of [a b/c]. If you want an improper fraction 6283u2000 you press [SHIFT][[FD].
As to the value of sin 45 you quote, you should be aware that it is valid for an angle unit in radians.
It is an approximation because the radian unit is based on the value of pi, which, as I said above, is an irrational number.
If you use the degree angle unit, sin45 deg is actually equal to 1/?2 or ?2/2 and this is clearly irrational, and it cannot be represented as a fraction. In conclusion it makes no sense to try to cast it into such form.
On the other hand, sin 30 deg or cos 60 deg are both exactly equal to 1/2. The calculator will convert them to a fraction.
On a more general note, the calculator will always be able to convert a fraction into an approximate decimal number, but the converse may not be possible. It depends on the number of display space available on the screen.
Is there any other kind of number system where there are no irrational numbers
No. As long you try to divide the circumference of a circle by the square of the radius of the circle, you'll get the ratio "pi".
Note that "pi" is a ratio, not a measurement in some units (inches? centimeters?), so it simply "is what it is", namely an irrational number.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
