Hitachi RAS-09UH Air Conditioner
Problem for Hitachi RAS-09UH Air Conditioner
Hitachi RAS09UH randomly pops 15A circuit breaker
By f_szita on Jul 09, 2009
My Hitachi RAS09UH was protected by 15A circuit breaker since it was installed in March of 2006. Starting with March 19 2009, at totally random times the circuit breaker would pop, and the AC would become completely dead. Resetting the circuit breaker allows the AC to be restarted, but at totally random times it blows the breaker. Changed the 45MFD compressor run capacitor just today and the breaker popped after about 3 hours of operation. It is suspected to be a problem during the start-up of the compressor, but I had occasions where it popped the breaker after about 5 minutes of (what appeared to be) normal operation, and resumed uninterrupted operation for days thereafter. Suggestions?
Comments:
Jul 09, 2009
- Many thanks for the recommendations. Additional clarification: This is a 9,000 BTU unit with a rated current of 8.5 A maximum. According to the factory specs, the min. Ampacity [A] is 10A Cooling Watts | Amps = 950 / 8 Heating Watts | Amps = 950 / 8 Max TD Fuse/Breaker [A] 20 Based on the above, I felt safe with a circuit breaker size of 15 A. The choice of a 15A breaker was validated in my mind as correct by the fact that the 15 A circuit breaker has not popped for the first three years of the life of this product. The power supply connection is 2x125VAC, fused by (2) 15 breakers, one of which is an unused spare, held for future expansion. Soon after the problem occurred a few times, I moved the AC supply wire from the "popping" breaker to the heretofore unused (spare) breaker. The random popping still occurred. Replaced the original (popping) 15A circuit breaker with a new 15A circuit breaker and moved the A/C supply wire back to this (now brand new) circuit breaker. The random popping still occurred. I realize that these units draw considerably more current during start, so I will test with a clamp meter the actual current drawn during start-up and during normal operation. This unit is running at a 25-60% duty cycle to maintain the indoor temperature, meaning that depending on the heat load, it runs a minimum of 3 to a maximum of 8-10 minutes, then it rests as much as 20-30 minutes or as little as 5 minutes before starting again. As a last resort, I may even try a 20 A breaker, although as I said, 15A was perfectly fine for 3 years, and once the problem started, two different (new) 15A breakers still tripped. With many thanks, Frank
Best Solution
posted on Jul 09, 2009
Helpful)
DavidMcLarty
Rank: Wiz
Rating: 83%, 26 votes
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Comments:
Jul 09, 2009
- BTW, do not simply put in a larger breaker as that would allow the wiring to overheat and cause a fire. Always size the breaker to the gauge of the wire.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hitachi RAS-09UH Air
Questions and Unsolved Problems for Hitachi RAS-09UH Air
Do you recommend Hitachi RAS-09UH Air Conditioner?
Answer
Answer
filter light blinks when the split unit is powered on. remote does not work during the blinking... (More)
Answer
air conditioner making rattling, grungy sounds; started recently What are some possible causes?
Answer
I am just trying to find instructions to operate a remote for a wall mounted air conditioner. It... (More)
Answer
Hi we have 4 Hitachi Split System Air-conditioners & 3 of the remotes have been either... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
