Question about Kenwood DNX7100 Car Video Player
Ipod nano My unit stopped displaying the album art. It says load error in that location. The audio portion work just fine.
Re: ipod nano
I bought this nav for my car and I attach my IPOD, however it doesn't give me an option once the IPOD is hooked up to the Nav screen to play my photos off my IPOD through the nav system. Can someone help me?
Posted on Jan 10, 2008
Re: ipod nano
Re: ipod nano
IT does not support Nano yet get ipod classic 80gb play all music and videos. I have been told in two three months KW will come up with softwerar update for Nano.
Posted on Nov 15, 2007
0 characters
3 Points
My album covers does not display when playing mi ipod
you need the correct cable some cables do not support need the cd-iu200v cable and you ipod will come alive and show movies and videos too.also for album art to show go to background menu and turn background off.
Feb 04, 2011 | Pioneer AVHP4200DVD Car Video Player
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Ipod 4th gen not charging on Jensen VM9311TS
The issue is that the 4th Generation iPod takes far more energy to run than your 4gb iPod. Updating the firmware has nothing to do with it. It's the amount of energy/voltage that this new 8Gig unit takes to run.
Think of it as a 4 cylinder verses an 8 cylinder engine. The 8 takes far more gas to run.
A/V Media Guy
Nov 21, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen vw9312 wont play ipod video
This unit does not have iPod video capabilities only audio, If you want to view video from your iPod you can get a universal cable that would charge it and also give you a audio and video output, this cable needs to be powered and grounded and hooked up to one of the radio audio video inputs. This link will take you to it.|65:15|39:1|240:1318|301:1|293:1|294:100
May 15, 2009 | Jensen's VM9312 Car DVD Player
Pioneer AVH-P4100 Ipod Video not playing
You have to set up the AUX output.
1. Touch the source icon and then touch "OFF" to turn the unit off.
(The unit will be in demo mode)
2. Touch the screen to display the touch panel keys.
3. Touch AV Menu you should see "Inital Menu" and touch it.
4. Touch AUX 1 on the inital menu to select desired setting.
5. Touch it until Ipod is selected (make sure you have the CD-IU200V connected.
6. Touch ESC. Ipod video should work now.
7. See Page 50 in Operation Manual for more information.
May 08, 2009 | Car Video Players
I have an older 30 gb video ipod and that worked jus fine but when i pluged in a newer ipod nano it doesnt connect and it does with a brand new 16 gb ipod touch. is there anyway to fix this problem?
When you synced to a newer version of iTunes, everything was fine, until you connected the nano and
the touch, which worked fine, and then you tried the 30 GB again and it would not work, right?
Upgrade the software in the 30GB, not with your original 30GB disks, but with newer disks supplied NOW
by Apple, since iTunes went to version 8.1.1 and everything should be back in sync.
Apr 10, 2009 | Dual Electronics XDVD8183 Car DVD Player
Kenwood dnx8120 ipod authorization error
From Kenwood Product support"
Thank you for contacting Kenwood USA Corporation. As an authorized agent for Kenwood, we are responding to your recent email inquiry.
Check the cable to see if it says "KENWOOD" on the part where it splits into three cable lines. Many locations are selling cables that appear to be the KCA-iP300V, but are not and do not have the Apple Authorization chip inside of them.
If it does show "KENWOOD," then try reseeting the iPod. This is done by switching the HOLD on and then off, and then pressing the Menu and Center buttons together until the Apple Logo appears.
Please feel free to contact us again with any additional questions.
James S.
Product Support Representative
Kenwood USA Authorized Call Center
PO Box 22745
Long Beach, CA 90801-5745
Phone: 1-800-536-9663 x 1918
Fax: 1-559-324-4594
Resetting the iPod worked for me... Good luck.
Mar 26, 2009 | Car Video Players
Jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Aug 20, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8
Assuming that your unit have a rear video/audio input, you need an adapter cable. 35mm to video/audio rca. You may find one on Ebay or RadioShack. Goodluck.
Jan 28, 2008 | Lanzar SVD26MUT Car DVD Player
Kenwood DNX7100 Car Video Player Logo
167 people viewed this question
Top Kenwood Car Video Players Experts
D. E. Hev
Are you a Kenwood Car Video Player Expert? Answer questions, earn points and help others
