Question about Biostar : I945P-A7 LGA775/945P/DDR2/SATA/IEEE Motherboard (MOTBI23)
Trying to put a mother board together need help
The power supply connection on the board has more pins than what is on the power suppy connection how do I connect this?
  • 1 more comment
  • LadyT18 Nov 13, 2007
    The power supply connection on the motherboard (I945-A7) has four extra pin connector than what is on the actual connection coming from the power supply. How do I connect this?
  • Anonymous Jun 21, 2008
    COBRA 11
  • bonsan Jun 21, 2008
    how do I connect the power supply
    Brigadier General:
  • 6,966 Answers
Hi LadyT18,
Apparently your power supply is an ATX 20-pin type (v1.x) and is the standard a year or 2 back. Your motherboard being fairly recent uses the new standard which is ATX1 24-pin type (v2.x).
Your options are:
1. Replace your power supply with a higher wattage/XX pin;
2. You may still use the old 20-pin power supply provided that it is rated 300 watts or higher. Additionally, please bear in mind that using a 20-pin PSU to an ATX1 (24pin) may cause boot failure and/or instability during operation due to insufficient power delivery.
I scanned part of a motherboard's manual to illustrate how this could be done. Below is the image for your reference.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
  • Louie  Role
    Louie Role Nov 26, 2007
    Hi again,
    Appreciate the rating and glad to be of assistance.
Power supply was removed and don't no where to put wires/acer aspire
cable has 20 or 24 pin group it will only go in one way
Apr 16, 2014 | Intel Motherboard
Power suppy fried, now new power supply will not power up
a 450 watt power supply will have the extra pins your talking about if this is a newer pc if not you will have to buy older used one on ebay or something to get what you need
Nov 10, 2009 | MSI K8T Neo-FSR Motherboard
I want you to try first swap the power supply box  of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU  then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
Oct 01, 2009 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
Jul 15, 2009 | E-Machines eMachines Desktop PC
4to8pin atx
You don't need an adapter from 4 to 6 pin, the mother board needs a 4 pin atx connector.
You can download the complete manual from here:
And you can see the pins layout.
Let me know if you need more help
Sep 29, 2008 | EliteGroup GeForce 6100SM-M Motherboard
you need the correct board for your model Samsung has alot of replacement boards that are all simillar but you need the exact one for your model number TV
Jun 21, 2008 | Samsung PCJ522R 52" Rear Projection...
do u have pw switch on right pins power p start with red on that oen go over one to conect the black try both ways never up down on pins tho side to side only ok
Jan 25, 2008 | Intel Desktop Board D845WN Motherboard
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
Biostar : I945P-A7 LGA775/945P/DDR2/SATA/IEEE Motherboard (MOTBI23) Logo
786 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
