2006 Cadillac SRX Logo
A
Amber Lynn Downing Posted on Mar 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is my dipstick located on my 2006 srx cadillac
Michael
Level 2:
Habit-Forming:
Scholar:
  • Expert 46 Answers
  • Posted on Mar 04, 2015
 Michael
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
46
Questions
0
Helped
21658
Points
135
Hi Amber,
I presume that you want to change the oil on the Cadillac. The link below will tell you how to change the oil, where the drain plug is and where the filler is a. It will tell you where the dipstick is.
Oil Filter Change Cadillac SRX 2004 2009 2006 Cadillac SRX 3 6L V6
This is a good, clear video.
Where is the oil dipstick on a 2006 Cadillac srx
please check this video, the video for replacement of oil and filter, it includes oil level inspection using dipstick.
https://www.carcarekiosk.com/video/2006_Cadillac_SRX_3.6L_V6/oil/change_oil_and_oil_filter#
I need help finding the block heater cord on my 2004 Cadillac SRX v6 AWD. The manual says it's located on the drivers side near the oil dipstick, but I haven't had any luck finding it.
When you open the hood, look for the oil dipstick, look UNDER the upper Radiator support, they're usually zip-tied up under there out of the factory from my experience.
I need to know where are my spark plugs for 2006 cadillac srx v6
Your spark plugs are located on the top side of the engine, if you follow down the spark plug wires it will take you right to them. You will have to unplug the spark plug wire to get to them.
6helpful
7helpful
2answers
Srx 2006 oil filter location, I can't fine the oil filter. Thank
just forward of dip stick. it is changed for the top.
I can not find the oil pan plug on my srx 2006
it is on the passenger side of the pan, if you cannot find it, you are probably looking at the trans pan, the oil pan will not look like a normal pan, it will be square and aluminum with all kinds of diamond looking deep etches in it.
1helpful
2answers
Replacing front turn signal bulb on 2006 Cadillac SRX
You must take the front wheel off, then remove the inner front fender panels (2), they are fastened with plastic pushbuttons. this exposses the light housings for the turn and fog lambs. This takes about an hour, but saves you alot of money.
2006 cadillac SRX , V-6
hi all engine sumps have a drain plug and it is the lowest bolt on the bottom if you cannot find yours because there is a lower cover so you cannot see the sump you will find the cover will have a access cover that can be removed if not this would be unusuall to have to remove the engine cover cpmpletly best of luck yates210456
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
