Question about Samsung HL-P5063W 50" Rear Projection HDTV
How do i connect my laptop
When i have my tv(hl-p5063w) connected to my laptop i get no picture
    Brigadier General:
  • 6,966 Answers
Assuming that the laptop is hooked up to the projection TV using the correct cables or connectors and still no video display on the TV, perhaps you need to lower down the laptops screen resolution first using your laptop's screen display before pressing the Fn + F? key.
To lower the screen resolution, right click on any clear area of your desktop, select Properties. click on the Settings tab, move cursor of Screen resolution to farthest left, Apply, Color Quality to lowest, Apply. Additionally, click on the Advanced button, Monitor tab, select lowest Screen refresh rate.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
  • Louie  Role
    Louie Role Nov 13, 2007
    Hi again,
    Soon as there is a display, you can try increasing the resolution till the projection TV blanks out again. Pressing "Esc" on the keyboard will revert settings to previous position.
    Cheers.
My problem is: samsung hl-p5063w. I have a new lamp and it works fine. The fans work all right. The color wheel works well. But no picture, only the screen is black. Low light without image. The timer...
I'm not a tech person, but from what I have learned it sounds like your digital board (input) connections. Try diffrent connections to see if you get a picture.
If you are using a coax cable for your input, try the rca type input. If you still get no picture after trying diffrent inouts, it may just be the digital input board. Again Im not a TV specialist, just sort of informed from the net.
Apr 20, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
HAS SOUND BUT NO PICTURE
okay the reason that the its turning off could be the fan isnt spining fast enoug hold your hand at the back of the tv to feel where the exhaust air if isnt good enough to help cool off the bulb then the fan may need to be replaced also the balast could be going bad and last check the power supply that feeds the balast make sure its a constant dc voltage
Mar 28, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
The television has no picture and no sound and everything is connected. What could it be?
Good Day..
Let's see...
do you have your TV connected to a power supply?
How long have you had you TV?
Have you ever change the lamp?
does it make any strange sounds?
you give me little information!
lets see..
if it's just doesn't start is the LAMP!
http://www.discount-merchant.com/SearchResults.asp?Search=WD-52725
if it make a click sound on the back or like strange noises then is the color wheel!
http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsung-cw-bp96-01854a-enc.htm
and about the sound. may be the analog board that is the one that controls the sound or maybe try to clean your TV whit compress air
http://www.discount-merchant.com/1068982-HL-P5063W-p/1068982.htm
Jan 03, 2010 | Samsung HL-R4667W Rear Projection...
No picture after replacing color wheel
every time I see this itbis a cable or plug that was left out or one that got pulled on and pulled the connector up out of the plug a little, you need, and not by sight by your hands to go over every plug and connector till you find one.
Larry Dillon
Aug 01, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Jul 18, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
