Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Washing Machine Top Load LSC9355AN0 agitator frozen
The agitator will not budge at all, and when turned on there is a lound noise, maybe from the motor. I checked the pump and motor coupling and they are fine. Is this the transmission frozen? Clutch? Please help!
Thank you,
Justin P.
  • Anonymous Nov 23, 2007
Had the same problem, just hade to replace the agitator.there are teeth on it and it was stripped out.
Posted on Feb 25, 2008
When i start my washing machine the water runs ,but theres no movement from agitater.what could be the problem?theres no noise,but the running of my machine.
Posted on Feb 24, 2008
  • 213 Answers
If the coupling is not cracked the transmission is bad. you need to remove the motor to check the coupling. looking under the wash you might not be able to see a hair line crack in the coupling
Posted on Nov 20, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Won't spin, agitator won't turn. Repair it or just get a new one? 8 yrs old.
Hello,if your washer won't spin first check to see if the motor is running, then proceed as follow.
1. If the motor is running, your washer probably has a frozen pump pulley or broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely or if it is frozen or stiff replace it.
If the pump belt is broken or looks quite warm, replace it but be sure to check the pump pulley before you change the belt.
AGITATOR: If the agitator won't turn, the likely cause is "Lid Switch" because if the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jun 09, 2010 | Maytag SAV2655A Top Load Washer
Agitator won't spin
put the agitaitor on the floor, put your feet on the outer ring, and give a sharp upwords pull. This should get the top section off of the lower section. Then turn the upper section over and you will find your dogs.
May 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool agitator not working!
Hello Roger.
Please do the following checks for they might just help.
Check that the water supply valves are turned on
Inspect the filter screens
Test for overheating
Inspect the water pump
Test the water inlet valve
Test the motor
Most probably this case may be due to a faulty motor.Good luck.
Jan 09, 2009 | Whirlpool LSR6232J Top Load Washer
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Spin Cycle (again) on Whirlpool Washer - Bad Noise
then the transmission is bad the part number is 3360629 since you know about the drive coupling the you know wher the transmission is all you need to do to change it is
remove the agaitator
move pump to the side
drop dow the motor
remove motor wiring at switch
remove the retaing clip from the transmission for the motor wiring
the tranny is held in place with 3 half inch headed bolts
reinstall backwards and you are good to go
Apr 16, 2008 | Whirlpool LSQ9610L Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Removing bolt in agitator arm
The bolt unscrews counterclockwise. Hold the agitator by the bottom vanes. If it won',t budge try tightening it first, just a little to break it free.
Dec 10, 2007 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
505 people viewed this question
Dan Webster
Dan Webster
Sal De
