Question about Dell DJ MP3 Player
My Dell DJ
Everytime I go to turn my mp3 player on, it goes directly to the rescue mode thing, and when it goes ther, i tried to click on everything, and nothing seems to wrk............any ideas???
  • 1 more comment
  • jen606-6277 Nov 25, 2007
    I also have the same problem with my Dell DJ Player. It goes right to the rescue mode. I'm new to the MP3player thing and I bought it off of EBay. It's a X-mas gift and it does't even work and I don't know a thing about them! Help!!
  • Quakes Dec 17, 2007
    I bought my 30 gig from someone from craigslist. The screen was cracked a little, but it was fine other than that. Some time later it froze, but after a few days it worked itself out (I now know how to fix this). Well, I dropped it the other day and it froze again. After fiddling with it for a moment, it restarted in recovery mode. I took it home to reload the firmware and all of that, but nothing happens. How do I recover from recovery mode? Is the hard drive done for?
  • Anonymous Apr 03, 2008
    i have the same problem it goes to rescue mode i try the pin hole on the side but not working still
  • 3 Answers
There is a tiny hole on the bottom of the player this is a reset button. push a pin or something into the hole and hold it there for a few seconds to reset the player(you shouldn't lose anything from the hard drive)
Posted on Jan 04, 2008
Firmware error
Try going into rescue mode by pressing the Play button while inserting the end of a thin object such as a straightened paper clip into the reset at the same time, then hold the Play button until your Dell Pocket DJ turns on.
Scroll to "clean up" and select. This just defragments your players hard drive, you won't lose any data.
If that doesn't fix it try replacing the firmware. Download the most current firmware from Dell's support website. Scroll to and select "reload firmware" in rescue mode. Connect to pc with usb cable and power on player. Double click the firmware file on your pc and let it do it's thing. This won't affect your saved data either.
If neither of those work you may need to reformat the players hard drive. This will wipe out anything you had on the player. Scroll to and select "format all" while in rescue mode. Select "yes" then just watch the progress bar. Good luck!
Feb 17, 2010 | Dell DJ MP3 Player
Dell Digital Jukebox
Anything unusual happen to the player before the problem started? Dropped it or perhaps unplugged it from pc while synchronising? The most likely fixable problem is a loose connector on the HDD/main board cable, or a failing battery/power adaptor giving the HDD a voltage too low. unfortunately however the HDD on these players is a bit vulnerable to rough treatment. When you connect it to a computer, does it still appear as normal or is it not recognised etc. What operating system PC are you using - perhaps formatting from the PC first before trying to install the firmware will help. Are you using the latest firmware from Dell or are you using a cd that came with the player? Is your player still under warranty or do you want to try and open it up and have a check yourself. Let me know more info and what you wish to try :)
Aug 17, 2007 | Dell DJ MP3 Player
The solution to many random problems is to simply reset your Dell DJ. This can be done by using a small, thin object (such as the tip of an ink pen) to press the reset button that is on the bottom-left side of the DJ. -or- Hold down the play/pause button while it's off, insert a paperclip into the reset button, take it out, and then let go of the play/pause. The DJ should open to a rescue mode, then run disc clean-up.
Dell Jukebox is stuck in Rescue Mode
did any of this stuff actualy work?? because i am having the same problem with mine the only thing is as long as i've had mine i didn't even know where the reset button was.
Mar 23, 2009 | Dell DJ MP3 Player
Did you get your dell dj fixed
its broken dude unfixable. sorry..... your just going to have to get a new mp3. I've tried everything and just threw that stupid piece of technology away.... couldn't even salvage the other parts to fix a cd player
Jul 07, 2008 | Dell DJ MP3 Player
Dell dj gen 20
it is possible the the battery cable is unpluged
Mar 03, 2008 | Dell DJ MP3 Player
Dell DJ won't reload or reboot
I would first suggest reformatting the DJ from Rescue Mode, and then try reloading the firmware from here: If neither of those work, it may be time to look into some repair options. John Dell Customer Advocate
Aug 06, 2007 | Dell DJ MP3 Player
It won't turn on!
Have you checked to make sure the lock on the back hasn't been switched?
Mar 31, 2007 | Dell Pocket DJ MP3 Player
Dell DJ MP3 Player Logo
173 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
