Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Water is leaking underneath my Solis Mas...
By truongbmd on Jul 09, 2009
Mostly clear water is slowly leaking underneath the machine; tends to come after pressing a cup or two
Comments:
Jul 15, 2009
- Thanks for the reply. I don't see a white plastic valve behind the brew unit on this particular machine but there is a small resevoir compartment that is frequently filled up with fluid. I have to drain it frequenly; recently, there is liquid accumulating in the used ground coffee puck container.
Solution #1
posted on Jul 10, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 326 votes
The only thing that comes to mind is the drain behind the brew unit under the white plastic valve.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
my machine will not make a cup of coffee...goes to brewing then nothing. Goes back to ready
Answer
We've had this for only a couple of months, and the dispenser has slowed to barely a trickle. I've... (More)
Answer
We have a Cuisinart DCG 500 Series. The grinder is making strange noises like it is losing power. It... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
