Question about Garmin Nuvi 660 GPS Receiver
Garmin 660 gps Bluetooth problem
Ok, i've tried everthing to fix my problem including resetting my device, deleting and setting up the bluetooth config, also downloading and installing the file to no avail.
Here is my problem: It was all working 2 days after i brought it and configured it. Could see all my contacts, txt messages and other stuff, make calls through the gps to my mobile (Sony Ericsson W850i)
How, when I start the phone and the 660 it detects and connects, I can see my txts and contacts on the 660 via bluetooth to my mobile, but the Bluetooth disconnects after 10secs on the 660. When I enable bluetooth on the 660 it just sits there with the message Enabling Bluetooth.
I've updated the software from Garmin including the Bluetooth patch...
Any Ideas!!!
Re: Garmin 660 gps Bluetooth problem
Note: This is for a 550c Street pilot
1) Turn on unit
2) Press VIEW MAP
3) Press SPEED in lower left hand side of map
4) This will bring you to the Trip meter screen on this screen press the round speedometer at the top of the screen for about 10 seconds this will bring you to the SYSTEM BIOS.
5) From this point forward be careful you can mess up your unit by changing the wrong thing.
6) Press NEXT until you come to the BLUETOOTH STATUS screen.
7) Now press UPDT P this should complete your update.
Posted on Nov 24, 2008
Re: Garmin StreetPilot c550. I received the "Updating Bluetooth Firmware" message out of the blue after ~ 8 months of normal operation. The status did not change after ~7 hrs in this mode. On the c550 there's a small fingernail recess at the top of the frame around the display, just under the "Garmin" logo; removing the frame carefully reveals a "Press to reset" tab on the right side of the display. Pressing this allowed the "Updating Bluetooth Firmware" procedure to complete. Press the frame back into place. Normal operation resumed (so far...).
Posted on May 17, 2009
I have a nubi660, and the bluetooth does not work. When trying to enable bluetooth - the screen freezes?
Any advice please?
Posted on Jun 21, 2009
Connect nuvi via usb. Go to sw folder. Throw away the files. Then go to web updater. It will find the additional files and than reupdate.
Posted on Jul 20, 2008
Problem fixed (Thanks to a fantastic support dealer Brian @ (
Download latest BT (version 3) with web updater
Connect NUVI to PC, go to dos prompt, change to drive letter of internal GPS , type in chkdsk /f (say N to convert lost links to files), go to maintenance mode, clear user data (ie favourites and phonebooks), go to bluetooh page in maintenance mode, reload BT, restart system, works great for me
Posted on Jan 09, 2008
Solution 5 above is awesome!!! It completely fixed my problem, as my Garmin 360 started dropping its Bluetooth connection every 5 seconds, after having no problems with the same phone for a year or more. Following the steps in Solution 5 and re-pairing did the trick. And this is after I got a $ 180 ticket for driving without hands free because my Garmin was dropping Bluetooth. Thank you!
Posted on Jun 13, 2010
I had the same problem with my Nuvi 260. I connected the GPS to my computer and ran the web updater and selected the bluetooth update and after restarting it worked again.
All is well again. haha
Posted on Jun 14, 2008
So far, so good. Thanks for the tips. We'll see how it goes - draive me crazy that I have to do this myself - the Garmin guy I called had absolutely no clue and I've been frustrated for weeks about this.
Posted on Jan 22, 2008
0 characters
3 Points
How do i use the bluetooth feature on my garmin 260w?
go into settings and see if it has bluetooth logo icon, if not then it dont have it , if yes then go into and add device and make sure your phone is visible on bluetooth settings, then search for device follow prompts
Jan 02, 2010 | Garmin Nuvi 660 GPS Receiver
Bluetooth connetion with Verizon Treo 700P
Looks like your saying you've updated your n?vi 660 to software(firmware) version 2.0, if so you're moving in the right direction. Unfortunately the n?vi 660 does support the Treo 700P but only seems to support the 'Hands-free' BlueTooth profile and this is often problematical as is the 'headset' profile with some device combinations, that's precisely why many phones and devices now support both profiles. Check the pairing information to see if you're using 'headset' or 'Hands-free', whatever you're using delete the pairing on both devices and see if they will let you pair in the other profile. Your Treo 700P is made by PalmOne ( so you may want to check for software updates from them. This kind of problem is down to the lack of a solid standard for BlueTooth communications and you will often find that settings that work for one combination of devices are unstable with another. Post back if this doesn't help or if you need us to clarify anything.
Aug 18, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth will not enable
This is solved in a related post by silentspoon
I just tried it for the same problem, worked great
Apr 23, 2009 | Garmin Nuvi 660 GPS Receiver
Bluetooth icon missing
The Nuvi 750 does NOT include bluetooth capability. I don't know what you saw, or what you think you saw, but Garmin's website is very clear on this issue. NO BLUETOOTH WITH THE NUVI 750
Feb 07, 2009 | Garmin Nuvi 660 GPS Receiver
Pairing my garmin nuvi to my blackberry
Nuvi 200 does not have bluetooth capability.
See this link:
- Jim
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Download and run the Garmin WebUpdater. There is a new version of the firmware availabe for the bluetooth.
Apr 25, 2008 | Garmin Nuvi 660 GPS Receiver
Blue tooth phonebook
The unit does not save the phone book, it loads it each time your bluetooth phone is in contact with it. To verify this, turn off the bluetooth phone, then try to access the phone book in the GPS unit. It should not come up.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - Bluetooth
I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
11,257 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
