Question about Motorola Mobility RAZR V3
Camera image options
My picture menu on my motorola v3r lists:
Go to pictures
Auto timed capture
pictures setup
View free space
The option to change between black and white etc. is missing. Should be between auto-timed capture and pictures setup. Any suggestions?
    Brigadier General:
  • 7,752 Answers
Re: Camera image options
Try having it reflash and see if that helps with an updated firmware flash. Take it to a mobile service center or a professional tech
Posted on Jan 20, 2008
0 characters
3 Points
I need the free subsidy password motorola v3r imei num is 352509015765963 bootloader 0A.52.
To Unlock Motorola RAZR V3R use Subsidy Password. But free subsidy password is not possible to get for this Model.You can get free code for NOKIA DCT Phones and Some other brands old phones.Visit the site
get Subsidy Password and unlock it easily.Then use with other GSM network ...
Nov 17, 2012 | Motorola Mobility SLVR L7 Cellular Phone
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
I have a Motorola Razr V3r mobile phone.The only key that works is the power up key & There is no display.Changed display,keypad & flexible keyboard connector.Still no joy .Any suggestions
Hi, No one will give you free unlock code for your motorola Razr v3r mobile phone unlock code
but you can get motorola Razr v3r mobile phone unlock code at cheapest rate from others or 100% money back guarantee from this third party Thanks
Hi, No one will give you free unlock code for your htc wildfire but you can get htc unlock code at cheapest rate from others or 100% money back guarantee from this third party Thanks
Oct 14, 2011 | Motorola Mobility RAZR V3
How do you change the time on a Motorola w220, not display the time actually change it without resetting the whole phone?
You don't actually have to reset the whole phone, go to the Menu,click on the "Settings" option,scroll down the options that are there and select "Initial Setup", it is the sixth option on that dropdown list, select it and click on Time and Date option,check whether the "Auto Adjustment" box is checked, if it then remove the tick and then set the time or date as you wish,without setting up the whole phone.!
Nov 23, 2010 | Motorola Mobility W220 Cellular Phone
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
How do i transfer my phone memory to the micro sd
You can store any multimedia files
on your phone’s memory in My stuff
so that you have easy access to all
of your pictures, sounds, videos and
games. You can also save your files to a
memory card. The advantage of using
a memory card is that you can free up
space on your phone’s memory.
My images
My images
contains a list of pictures
including default images pre-loaded
onto your phone, images downloaded
by you and images taken on your
phone’s camera.
My images options menu
The options available to you in My
depend on what type of
image you have selected. All of the
options will be available for pictures
you have taken on the phone’s
camera, but only the Use as, Sort
by Grid (List) view
and Memory
options are available for
default images.
Send - Send the image to a friend.
Use as - Set the image to appear on
your phone at certain times.
Move - Move an image from the
phone memory to a memory card or
vice versa.
Copy - Copy an image from the phone
memory to a memory card or vice
Delete - Delete an image.
Mark/Unmark - Select multiple files.
Print - Print an image via PictBridge or
File - Change the name or view the
information for the file.
Create new folder - Create a new
folder within the Pictures folder.
Slide show - Start a slide show.
Sort by - Sort images into a specified
Grid view/ List view - View each
image in grid or list type.
Memory manager - View the memory
Jul 26, 2009 | LG Secret ? KF750 Cellular Phone
V3r motorola free download
hi rhonda,
             just turn on the bluetooth in ur laptop and in ur the picture you want to send..go to options and click send via bluetooth...ur phone now searches the connected bluetooth devices around it..once it detects ur laptop, select it and give dis way u can transfer data( pictures, files, videos) from mobile to laptop....
good luck
Jul 04, 2008 | Motorola Mobility RAZR V3
Main Menu problems
your phone has deleted its own menu options happens all the time and they say machines are smart is your clock out too?
Unfortunatly you wi;ll have to take a different route to get to your phone options or you will have to invest in another many have done this unfortunately but if its been under 6 months since you got it you can get a new one
Mar 30, 2008 | Motorola Mobility RAZR V3i Cellular Phone
C261 memory problems
the sounds on your phone may use much places than your pictures. to see the free space available when you've delete, go to the main menu, select multimedia, open pictures or sounds, press the main menu and at the bottom, open "view free space" you can see how much free space you've got while you delete the unuse pictures or sounds. also you can add more free space to your phone by purchasing: if you've got webaccess, use it and go to google or yahoo tape "incruse free space on motorola C261" and browse you'll get access to the merchants for your needed. hope this will help you, Bye.
Jun 17, 2007 | Motorola Mobility C261 Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
