Televison & Video Logo
K
Ken Amstutz Posted on Mar 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
.I need a power cord for my Sony Bravia Television
gemagm
Level 3:
Master:
  • Sony Master 689 Answers
  • Posted on Mar 04, 2015
gemagm
Sony Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119847
Points
1147
You can find that at most any Electronics supply store in your area. You might even try a local electronics repair shop,(they may sell you a good used one)
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Power cord
Sony direct or any electrical outlet .
Sony Bravia - sound pulsates off and on - several minutes on and then 10 seconds off. We checked cable box and HDMI cord on another TV, and sound was fine, so narrowed down to the Sony Bravia.
Actually try one more thing before concluding that there is something wrong with the sound board or one of the wires in it on this Sony Bravia television. The cable box settings might not be just right for this television. Are you currently set to pcm or bitstream on this cable box? pcm might also be displayed as 2 ch 48 or 96 khz. Play around with the sound settings and see if one or the other will solve this sound issue before writing off the television.
MY SONY TV HAS NO PICTURE AT ALL BUT THE SOUND WORKS FINE
I suggest that you check the cords again and see if they are loose. The same thing happened with my sony HD television and I found out the cords had not been plugged in completely. Also check the display settings and TV settings by using your remote. If these do not work, try getting your television checked by a repairman as maybe he could fix your television set.
2answers
KDL52XBR3 Sony Bravia turns off automatically after minutes of being on. Then it turns back on automatically. THe picture and sound are great and problems when on. What could the problem be?
Tv power supply board is having problems,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I need 10' long power cord for sony bravis 48" lcd television. where in the world can ii find one? it can be longer.
Tries websites like Amazon.com,Partstore.com Ebay.com to buy a power a/c cord for LCD tvs.10' long don't know,must ask the sellers vendors for that info?
1helpful
The standby button is flashing twice- sony bravia klv-40v550a
Unplug the power cord for 30 min, plug back in and turn on.
Should ths not work seek repair or replacement
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
