SOURCE: Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
SOURCE: Replacement fuser unit for Samsung CLP-510
The part number you need is JC96-03239C-N
You may order it through this website; you'll need to call them for pricing information. They are a reputable company that I use to obtain parts.
Thanks and please give this solution a thumbs up rating, solving your problem.
SOURCE: SAMSUNG CLP600 COLOUR QUALITY
I've had the same problem with color problems, especially with cyan (blue). I have found that many of the toner cartridges I receive are defective. When I receive a new one, I try it out for a few pages. If the color isn't perfect I return the cartridge and get a replacement. After 1-2 tries, I get one that puts down good color. (A really bad solution I know, but it does get the job done.)
