Question about RCA F36674ET 36" TV
TV Turns Itself Off. What would I have to do to fix this problem? I was watching tv the other night and it turned it self off. when i tries to turn it back on, it cliked on then click right back of three times and then stayed off. I unpluged and tried it again with the same results. Help!!!!
  • cougarfan Feb 04, 2008
    I have this exact problem. However, trying to turn it on enough times, now all I hear is a chirping that is indicitive of the power circuitry, so I'm guessing FBT failure. I inherited the TV when it had a similar flyback problem and was also chirping. I swapped out the flyback and the suggested resistors and caps (R14704, C14710, and a few others) as well as the horizontal output transistor. TV worked great for about 5-6 months. What could have caused this new FBT to fail? Is there some greater problem I might have that will cause a new FBT to fail again? I'm hesitant to invest in the repair if it's going to just happen again.
  • cougarfan May 11, 2010
  • 934 Answers
That set is a CTC197 chassis with a common problem - flyback or more commonly referred to as the FBT...
The FBT is a high voltage transformer which delivers a great deal of voltage to the crt to light the tube. The FBT is RCA p/n# 237502 and a ring test can confirm its failure. Another shortcut technicians use is to unsolder the collector of the HOT and power the set. If it powers with up and has audio you're in business, just replace the FBT and it's recommended to replace R14704 its an 82k ohm- 1/2w resistor and C14710 a .01/1kv cap as well. I believe if you order these as a kit, (ie: original RCA FBT), the two other parts are included - but ask to make sure.
You might also check for continuity across E & B of the HOT with a multi-meter while you're in there and if you get any resistance at all the HOT is shorted also... Or for simple reliability just replace it anyway.
Hope this helps!
Bill
Posted on Nov 13, 2007
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
Tv turns on every night at 7:00 and turns off at 8:00 by itself. If we are already watching tv it defaults to a specific channel at 7:00 pm automatically.
Dear customer,                Check you tv's sleep timer and scheduler settings and disable them. thank you.
May 02, 2009 | RCA Televison & Video
RCA 32V434T TV turns itself off and on by itself. Any suggestions on how to fix it?
When your tv turns on by it self you prob have the alarm set. For the tv to turn like a clock would go off when u need to get up. You need to check the the sleep/ wake up timer to see if it is set.
Jan 25, 2009 | RCA 32V420T 32" TV
"TV, turns it's self on"
Yeah Go Into Your Options Menu And Find The Wake Up See If Its Set To Turn Itself Off. I Use This When I Go On Vacation So People Will Hear The T.v On And Off At Intervals.
Jan 05, 2009 | Televison & Video
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
TV KEEPS TURNING OFF ITSELF
this sound like your regulator is not working see if the set turns off in white senes if so replace it
Oct 15, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
My tv screen goes green and then turns off by itself
mine does that to but when i turn it on its blue and in like 5sec. turns off by its self
Nov 09, 2006 | Premier Mounts Universal Flat Panel Wall...
Televison & Video Logo
155 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
