Question about AudioBahn AW1206T Car Subwoofer
HELP i just bought an audiobahn second hand but i dont know how to hook it up its an audiobahn 12" eternal series it has like got like 8 hook ups for the wire
    Problem Solver:
  • 19 Answers
AJ driver is correct. You will need an amp to test out the speakers and make sure that they are functional. I would reccomend looking at local pawn shops for a cheaper, used amp -- this way you don't have to spend too much money. Also, look the speakers up online and make sure that you buy the proper speaker cables for them to assure the best clarity.
Hopefully this helps you solve your problem.
Michael Lazar
http://www.AudioholicBlog.com/
Posted on Oct 03, 2008
    Problem Solver:
  • 15 Answers
Hi there, do you have an amplifier to hook it upto mate? if you do its best to go into your local halfords etc and ask for a wiring kit for you car audio, or search on ebay, theyre normally around 20pounds. then it will come with instructions on where certain wires go etc, the 8 outputs are probably so you can connect two subs together. they should have a pos and neg on them somewhere. if you dont have an amp you probably need to buy one. if you have any further queries just ask mate
Posted on Nov 14, 2007
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
I need help hooking up a 12" alum audiobahn
check out audiobahn.com and click on the tech support. then you while see some diagrams for subs, for different ways check it out it helped me out with my aw1508x being pushed by two a2300hcx
Mar 01, 2010 | AudioBahn AW1206T Car Subwoofer
I have a blowe 15
depends on how you blew them and how old they are if they are within a year you can try to write to the company and see if they will fix them if its just the rubber surround then its an easy fix hot glue it or gorilla glue let it dry and hook em back up
Feb 28, 2010 | AudioBahn Eternal AWES15P Subwoofer Car...
No sound from sub
simply give it a 2 wire signal and you should hear something! if not then depress the cone lightly back and forth, if you hear alot of scratching/scraping sounds, prognosis in not good.
Sep 15, 2009 | AudioBahn AWES12P Car Subwoofer
I need the right box for my subwoofer
go to audiobahn.com and you can download your manual for your audiobahn under tech support
Apr 03, 2009 | AudioBahn AW1251 Car Subwoofer
JL 1000/1 turns off
Does the amp have a volt meter on it? That tends to be pretty helpful in determining if it has enough power. I had to run an 8 gauge wire from my battery to the amp to get enough current to power an audiobahn 6 channel 6601t, with a dual voice-coil audiobahn 12 inch eternal. In the summer mine hits a thermal protection unitl I roll down the windows and ventilate the car, but that does not sound like thermal to me. It could also be the wrong impedance for your amp/sub combo. If you are making these speakers distort, you should be deaf by now. a 1000 watt amp is no force to be reckoned with. Your sub is 1.5 to 4 ohms. I posted a link to where you can check if it is wired properly. If these are distorting, it sounds like you have these wired for the wrong impedance. There is no way you should be making this setup distort at all without blowing out windows. It could be that you need 2 batteries, or if you are a pro DIYer Get some A123 batteries from a dewalt product. They have insane discharge. But I would recommend just getting a new battery (see bottom link), and making sure you have a 4-8 gauge wire going to the amp. I know a lot about batteries, as I built my own EV, so tell me how you have these subs wired, and how you have the amp wired to the battery.
http://www.crutchfield.com/S-B5qDIPXbsfV/learn/learningcenter/car/subwoofers_wiring.html
http://akamaipix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_mono.jpg
http://www.optimabatteries.com/audio_electronics/
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Best way to wire the audiobahn eternal
Well, from what I can find, the best you could do is 2 ohm stable. This is only if you have a decent 2 ohm stable amplifier. In order to wire it to 2 ohms you will need to take the positives and hook them together and run one wire to the brigde positive of the amplifier. Then take the negatives and hook them together and run one wire to the bridge negative of the amplifier. Make sure you have a good enough amplifier to run this sub also. I would definately use a mono block amp that is 2 ohm stable and at least 1000 watts. I'm not sure if you have the 10",12", or 15" but 1000 should do it. There is one key that many people miss.......it is just as bad to underpower subs as it is to overpower them. And make sure you get a quality amplifier....if it is a brand new 1000 watt amp and it is under a hundred dollars you are not getting a good amplifier. Amps that I would recommend getting are gently used high end amplifiers, namely Memphis. I'm sorry I've rambled enough, but if you need anymore help just let me know. Good luck
Sep 15, 2008 | AudioBahn Car Audio & Video
AudioBahn AW1206T Car Subwoofer Logo
174 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
