Hi, if you still need a photocopy of instructions email me
[email protected]
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me
[email protected]
