SOURCE: brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
SOURCE: Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
SOURCE: We have the intellifax 4100. It keeps telling us
Hi Sandy58 this is the fix. all you have to do is: open the front cover (leave it open) and press the clear button then it will ask you NEW DRUM AND YOU ENTER 1 FOR YES and that's it good luck.
any other question please email me,
thank you.
SOURCE: reset the drum count on a brother intellifax 2800.
Drum counter is reset by installing a new drum which contains a specifically designed "starter sheet" that is passed through the machine when it is installed, and triggers the paper sensors in a specific pattern, resetting the electronic counter.
If you have installed a new drum and the message remains......I suspect that it was a remanufactured unit that did not include the "starter sheet" Is that the case?
