Question about Sharp HT-DD5000 System
How to turn off the STANDBY Mode
Unit is on, but no sound and the stand by light will not go off.
  • Anonymous Apr 22, 2008
    have the same problem cant get sound from tv but vcr and dvd player gets through to the speakers
  • dirtysox Apr 28, 2008
    I have everything hooked up,but standby button will not go off.
I cant get the stand by light off..
Posted on Aug 14, 2008
Turn off stand offhow
Posted on Mar 21, 2008
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
How do I get MR Slim out of standby mode
if unit is hard wired try turning circuit breaker off and then back on
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
My reciever wont power on but the standby light will come on and when i press power, the stand by light just turns off
It sounds like the output transistors may be putting this into protection mode causing the unit to shut down to avoid further faults. It will need to be serviced.
Dec 02, 2010 | Audio Players & Recorders
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Jul 06, 2010 | Audio Players & Recorders
I have a Home theatre DVD SC-PT460. Turned on this morning and the red stand by light is on but i cannot get it to come on?
the power supply in your DVD player may not have the proper voltage to the electronic switch and therefore the processor is in standby to protect the device.
Or you may have a remote that has left the unit in standby mode. check the user manual to see if this is the fact.
Checking manufacturers site in knowledge base usually has the solution for a "stand by mode" issue.
Or call and talk to a technical support rep.
Jan 23, 2010 | Panasonic Televison & Video
Stanby mode
Goto control panel, performance and Maintenance, Power options, Power options property, hibernate tab, enable,apply, advanced tab, select how you want to stand-by or hibernate unit, apply.
Mar 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know
Feb 13, 2008 | Denon AVR-1804 Receiver
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Sharp HT-DD5000 System Logo
764 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
