2000 Ford Ka Logo
V
Victoria Posted on Mar 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In slow moving traffic car will stall and will not restart for about ten minutes
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Ford Master 1,449 Answers
  • Posted on Mar 03, 2015
Daniel Mc Entee
Ford Master
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275896
Points
3556
Get your codes first ,with a cheap code reader .your car will tell you what is wrong .plug into the diagnostic plug.
In slow moving traffic car will keep stalling and takes ten minutes to restart
Any gauges that do not read correctly like they should ? Sounds like a bad intake air temp sensor or coolant temp sensor
1helpful
Stalled while driving
Sounds like the engine is starving for fuel. You might try changing the fuel filter. It also cold be water in your fuel tank. Try putting some dry gas in the tank.
My question is: I have a 1999 TERRANO QD32ETI engine and the problem which the local agents and private mechanics cannot solve is that when it's on the highways the engine performs well; that is i
I have a 1999 TERRANO QD32ETI engine and the problem which the local agents and private mechanics cannot solve is that when it's on the highways the engine performs well; that is it accelerates perfectly. However, when the vehicle comes to a dead stop, and you go for a quick take off the engine cuts out; it restarts quickly; now,when you make a slow acceleration after stopping the engine does not stall, but this can be a dangerous situation when crossing traffic on the highway or moving off from the traffic lights. We checked the computer, fuel pump and the injectors; our opinions differ and somehow
we feel the problem may be the fuel pump. We would appreciate your comments. Our many thanks for your kind assistance. Thanks Tony.
My mazda 626 at idle read 1500rpm. when moving it will suddenly stall, at times when moving slowing in traffic, it stalls. what can i do?
what model mazda?? check for a cracked air intake hose air filter to throttle body replace if cracked. It should only be idling at 750rpm
Initially starts fine, runs fine, then stalls at the first stop.
This is a fuel pump issue. i would replace it and the lines as well.also, a minor tune up wouldn't hurt as well. wires plugs distributor cap points etc...
1991 Mercedes 190 starts but cuts out when driving
You could have a defective fuel pump, when they go bad they can draw enough current to fry the relay contacts, so I would suggest you test how many amps the fuel pump is drawing, I have fixed this very issue of repeated relay replacements, it was always the pump was shot.
Vitara 1.6 cuts out
Are you quite sure it is not overheating? Your mention of heavy traffic, ie. stop and go, would tell me that your radiator fans are not working. I had a car with bum electric radiator fans. It worked fine if it was moving a lot. But in slow traffic, it would get warm enough to have a vapor lock or something without setting the engine-hot light.
4helpful
2answers
1996 Camry 100 km stalling
You have one of two very common problems.
Number one may be a stuck open EGR valve
Number two would be a failing Idle Air Control valve (IAC).
Try this: Open the hood & locate the EGR valve, close to the firewall, behind the intake. Find & take with you a small hammer. The next time that it happens, open the hood & tap on the EGR valve. If it is sticking "open" the tapping may dislodge the carbon particles that are keeping it open.When the EGR valve is open, exhaust is getting into the intake at idle, and this will def stall out the car.
There is no repair to the IAC valve, it would need to be replaced if it is bad.
One of these two scenarios will cure your problem, I see it every day.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
