Question about Nikon D40x Digital Camera
Initialzation error. Contact Nikon
I've gotten this message several times when the camera was exposed to slightly cooler tempertures (60 degrees), which really isnt that cold. The only way to get it to work was to hold it under a lamp for several minutes to warm it up and then it would be fine. Any ideas on what the real problem might be and do I have to really send it to Nikon to get fixed?
  • 150 Answers
I'd call 'em and ask about it. My D70s has seen some of those temperatures, and I was able to take photos. Now the D70s is a little more rugged than the D40x (that is what this one is, right)?
Posted on Nov 23, 2007
Error on nikon d 70s
I occasionally get an ERR on my D-90 and it seems to happen for different reasons. Sometimes, it's kinda hard to figure out and it's hard to clear as well. One way I get it, is if I try to shoot without the SD card installed. I've also gotten it when I've been in manual mode and the settings were so far off that the camera could not function as set. So far, I've always been able to clear the ERR by turning the camera on and off if nothing else works.
I went to the D-90 manual and could find nothing about error messages nor could I find any reference to error messages in the table of contents. I happened upon what Nikon calls a Q&A index in the front of the book before the main index. Down in the list of questions, there was one which said "What do these warnings mean?" then a box which said error message and a reference to page 255 in the back of the book. I went to page 255 it showed a multitude of messages of different types but only one ERR.
The explanation was that this indicated a "camera malfunction" and to clear it, you are supposed to release the shutter. In the next box, it said that if this condition persists or occurs frequently you should contact Nikon Tech support.
Interestingly, when I get this message, the shutter will not release and I have to turn the camera off to make it release. When I turn it off and back on the error message has clear.
I hope this information helps with your D-70.
Incidentally, I've found the people at Nikon tech support to be very friendly and helpful.
May 25, 2014 | Nikon Cameras
Nikon d60 will not take picture
The Nikon D-90 users manual says on page 256 that the ERR message indicates a camera malfunction and that it can be cleared by releasing the shutter.
I've found on my D-90 that the only way I can get the shutter to release is my turning the camera off. When I turn it back on the ERR message is gone and the camera functions as it should.
Occasionally, I have had to remove and reinstall the battery to make the camera turn off but this happens only rarely.
The users manual says if the condition occurs frequently or persists that you should contact a Nikon authorized repair center. I suggest that you contact Nikon tech support at to see what they suggest. I think this information would apply to the D-60 as well.
Feb 06, 2014 | Nikon D60 Digital Camera
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Nikon 5100 - sd card is not recognized occasionally
Go on the Nikon site and get the firmware update, I had the same problem after I tryed to use 16G card.
Dec 20, 2011 | Nikon D5100 Digital Camera
Err message in my LCD control panel. I've removed tthe battery cleaned lens contacts, put in a new memory card and still ERR message. Nikon D90
Nikon Imaging Products Support Page:
Click here for repair information.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 14, 2011 | Nikon DSLR D90 Digital Camera
No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
May 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
My nikon camera lens won't work
You must have cleaned/repaired by a professional.
Nikon is in Melville, NY or you may contact, an Authorized Service Center in Florida for an estimate.
Apr 20, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Upright whirlpool freezer
not all causes are a FREON leak. is the compressor running
Mar 14, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
"System Error" message in LCD
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these: Use the memory card that originally came with the camera (or a Nikon approved card) Remove and replace the battery If the error is still displayed, contact Nikon's Service Department. If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon D40x Digital Camera Logo
26 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
