Question about Lexmark T642 Laser Printer
Paper jam 202 with no paper in printer
Machine shows pj 202 no paper in printer checked everywhere?
  • MichelleO145 Feb 24, 2009
    This is a great explanation and helped me find my exit switch is gone. How can I over-ride this and resume printing?
  • Anonymous Mar 19, 2014
    I am showing a printer jam but there is no paper in the printer
  • Lexmark Master
  • 1,113 Answers
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Also remove print cartridge and look behind it, if this machine has duplex unit installed you will need to lift it off that first to axcess all areas.
Check all doors are shut.
pic of rear of fuser and exit switch in red circlepaper jam 202 with no paper in printer - d3f7db6.jpg
Posted on Nov 13, 2007
  • Soulvisitor
    Soulvisitor Nov 13, 2007
    To get to fuser you will need to remove rear covers , yes you will need a screw driver oh and turn the power off and unplug is probally a good idea too, this is the area you need to play in.
  • Soulvisitor
    Soulvisitor Nov 16, 2007
    please rate solution
Thanks so much. it worked!!! this solution should be posted in the regular instructions!!!!!! you were most helpful.
Posted on Jun 14, 2008
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 28, 2010 | Lexmark C762dn Laser Printer
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
Canon MP470 printer jam error the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
202 Paper Jam
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
Lexmark T642 Laser Printer Logo
2,149 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
