Fisher and Paykel DEGX2 Dryer Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
Have DEGX2 Dryer. Blowing and running fine. No heat. Believe I need a new element. Any manuals or direction sheets on replacing heating element 395711?
  • Anonymous Mar 12, 2014
    Need to enter diagnostic mode on fisher paykel degx2
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3828
Points
20
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
  • rmulenex Sep 17, 2011
    Last year this dryer failed to heat - called tech - they replaced heating element - 2 days later unit went down again - tech cam back cleaned out dyer vent. After 325.00 spent unit worked fine. Almost 1 year to date -unit failed to heat again, decided to look on line for repairs info as I was sure I would replace before having another service call charge. Found this video - took apart reset and put back together. Works beautifully. As a femal, was quite impressed I corrected the issue. I recognized the unit had probally overheated due to numerous of continues loads that are typically not normal for our family. Thanks for the video instruction!
Anonymous
Level 3:
  • Master 552 Answers
  • Posted on Mar 06, 2011
Anonymous
Master
Level 3:
Answers
552
Questions
0
Helped
536793
Points
1583
The video below explains how to open and repair a fisher paykel dryer.
http://www.appliancerepairlesson.com/
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2937
Points
I have the same dryer and had same problem it was really simple to fix it needs cleaned inside and may have to hit the red reset button. open the lid and on each side theres a plastic cap pop it up with a flat head unscrew them lift the lid and youll find two more screws on the face of the dryer take the out and simply lift the face pannel strait up clean all the lint out and check the red reset button on the bottom
Fisher Pakel dryer wont heat all the time
open round housing on left inside where the lint catcher is. clean it. if that not solve your problem then replace reset switch. hope it will help you.
F&P #DEGX2 dryer seems to work fine but no heat. checked vent and all is clean. the air is cold I would think I could change out the heating element myself if I could find any type of diagram...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Heating element not putting out much heat and periodically pops the internal breaker. When it is working, it takes 3 times the normal amount of time to dry a load.
restricted air flow, disconnect vent tube dry a load of clothes. You can use a leaf blower or a shop vacuum to blow out vent tube, Tim
Everything works fine but, no heat
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Cloths take excessive time to dry, no blockages, heating element is hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Squeal when dryer turning
The problem is that your dryer needs a new drum bearing.
Won't heat - otherwise acts normally....
You could check for obstructed vent of excessive lint.
I have an old dryer manual for fisher/paykel
for the x1, how different can they be? LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5helpful
4answers
My fisher paykel DEGX1 won't heat up. everything else works fine.
If you have the same I do then it's the circuit breaker on the heating element. You have to take the front of the dryer off: Two screws on the top under the caps. Then lift the top alittle and you'll see the two screws on the front top sheet metal. The front then can be removed by pulling each side out and forward. The orange button is all the way at the bottom. Push and you'll hear it click.
3answers
Dryer is not heating well
run for one cycle with the hose disconnected from wall. if it dreis faster then you have a restriction in the wall or ta the screen or flapper outside
1helpful
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Top Fisher and Paykel Dryers Experts
Virgil Watts
john h
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
