Question about ASUS A8N5X Motherboard
Memory slots 2 of my 4 memory slots just stop working can help me??
  • 85 Answers
Best way to test it is if you run a diag.
Posted on Nov 13, 2007
Ms-6741 ver1 mobo. blowing ram on no2 socket. help please.
first check the specifications for your motherboard every motherboard has a memory limit for each slot you will be able to install the only limited memory given by the motherboard more will cause problem as you said remove the memory stic from slot 2 and insert them to the 1st slot and see what happens if you have still the same i think you have problem with slot
Dec 29, 2011 | ASUS M3N72-D nVidia nForce 750a SLI...
No matter what size memory I install, it only recognizes 1/2 of it. What am I dolin wrong? Thanx, Tom the Elder
try booting up one memory at the time
-memory 1 to memory slot 1 boot computer see if it will work. -memory 1 to memory slot 2 boot computer see if it will work.
-memory 2 to memory slot 1 boot computer see if it will work. -memory 2 to memory slot 2 boot computer see if it will work.
the reason for doing this is to make sure w/c one is defective if it is the memory slot or the memory it self, you can also check the manual to see what the maximum memory the motherboard can have.
Feb 24, 2011 | SuperMicro SUPER 370 SWD Motherboard
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
Mar 31, 2010 | Computers & Internet
New memory not recognized by Compaq Pavilion a1200y
most probably the problem that you have is not on the RAM stick itself but on the memory slot. Both memories can be detected by slot 1 indicates that both are working.. both working memories cant be detected in slot 2 which indicates a bad memory slot
Mar 16, 2010 | Computers & Internet
Dell vostro 400 2 beeps in bios post test
The cause of beeping is the memory problem. maybe the memory stick is not inserted correctly. If your memory stick will not correctly inserted it will damaged the memory slot. Try to use the other slot, if the same thing happen. You memory slot will be damaged you need to bring you motherboard to the computer repair center. Ask first how you will pay, if the labor cost is high. its better to buy a brand new motherboard.
Aug 01, 2009 | Computers & Internet
Psp memory problems
have you tried using your memory stick to other units or computer?
1. if its not working it might be damage.
2. but if its working your memory slot in your psp has the problem then look for a technician that could fix your psp slot for memory stick.
i can see that your memory stick and the psp memory slot is not connecting with each other.. hope it help. for more concerns send as a message
May 21, 2009 | Sony PlayStation Portable (PSP) Slim...
Memory upgrade problem
Try each stick one at a time in each slot and if one doesnt work, then thats the bad stick.
Is it dual channel?
How many slots total do you have?
Feb 04, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
Memory / ps/2 problems
If it boots then you would get the bios check then windows boots up, if your's not getting a picture then it may be only getting as far as the bios then stopping, it sounds as if the memory may be the stumbling block as if i remember the board is new, unless this is a faulty unit as the ps2 port should work i think there is a stress break on the motherboard somewhere.
Jun 20, 2007 | Foxconn NF4K8AC-RS-1.0 Motherboard
ASUS A8N5X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
