Back to:
Tags:
Scanners
Generic problem for all Scanners
Scanner instruction
posted by ladyammour on Nov 13, 2007
I would like the instruction for lexmark x 4.270
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 24, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
for some reason im having trouble to installing my scanner to my laptop. it tells me that its been interupt and it can not complete the instalation
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on scanner instruction:
I don't want to Accept this solution
Solution #2
posted on Nov 13, 2007
Not Rated (0)
shugster
Rank:Wiz Wiz
Rating: 80%, 84 votes
can you give me some more information to fix this problem ?
is the scanner working at present ?
what instruction do you need ?
Thank You!
Can you Help with these Scanners problems?
Canon DR-2580C Path-Through Scanner
All of a sudden whenever I scan documents there is about...
HP ScanJet 2400 Flatbed Scanner
I have driver but ican not install the driver onthe vista.
IBM IdeaScan Flatbed Scanner
i have a ibm idea scan 2000 machine number 0275-012 and i...
Scanners
Vimicro USB PC Camera
Epson Perfection 1660 Photo Flatbed Scanner
When I push the print button on the scanner and select...
Loading problems.
Repair Service
Find Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
