Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer help The washer would fill but would not do anything after that. I replaced the timer, now the washer fills and washes but when it gets to the rinse it does not drain or spin. the timer clickes but nothing no noise nothing. I checked the belt and its fine. The washer washes so the motor is working and the pulleys good. Please help
    Scholar:
  • 196 Answers
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Posted on Jan 08, 2008
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Washer fills with water but the timer is not moving
timer sticking if you can get at it spray the timer with wd40 penatrating spray or simmilar if that doesent work it the timer clock probably cheaper to buy a new washer than have this replaced hope this helps ivan
Sep 25, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
    The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
    Mar 13, 2009 | Washing Machines
    Washer will not fill
    not your timer / if anything its eather the water valve or the water slector switch
    Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
    Frigidaire front load washing machine won't stop filling
    it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire Washer/dryer combo
    Dtronics,
    A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
    hope this is helpful
    handiman518
    Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
    Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
    135 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
