Bought car today was in hurry under impression the car had the cd magazine in glove compartment got home was looking over everything nothing there a panal that looks like it can be removed but not sure yet how or what it's for.
If it's a factory unit, call Ford dealership and tell them your vin and they should be able to tell you what magazine it takes. To remove, there's 2 screws at the bottom of the center console, inside next to cd player, under rubber mat.remove them and complete plastic trim, console bucket, will lift out.might have to wiggle it a little but will lift, then there's 4 screws holding bracket for cd player. Unplug and remove. You maybe able to see part number without removing player
My 1999 Beetle did the same thing. I didn't have any luck repairing it, even tried a different magazine but nothing helped. Fortunately I found someone local selling a used trunk-mounted CD changer for $10, so I bought that and it worked like a champ.
So for me, I ended up having to replace the CD changer to fix this problem. Hope you have better luck.
It's quite a job to do,but if your up to it here's the step's.
1 REMOVE THESE PART'S
a. cowl side trim right hand side
b. front door scuff plate right hand side
c. no.2 instrument panel under cover
d. glove compartment
e. with cd auto changer:instrument upper finish panel
f. with cd auto changer:cd auto changer
g. audio amplifier
h. ecm
2 REMOVE CONNECTOR BRACKET SET SCREWS
3 REMOVE BLOWER UNIT
a. disconnect the connector's from blower unit
b.disconnect the wire harness clamp's
c.disconnect the evaporator temp sensor connector clamps
d.remove the 2 screw's,bolt and nut,than remove the blower unit
DISASSEMBLY
1 REMOVE BLOWER MOTOR
remove the 3 screw's and blower motor
REASSEMBLY
reassembly is the reverse order of disassembly
INSTALLATION
installation is the reverse order of removal.
This procedure is from alldata.
Like I said alot of work.Good luck.
most cd changer magazines are the same, the best way to find a replacement is the goto an audio/video retailer and speak with an agent about trying some in your cd changer.
i had to do the same thing for my 07 mercedes c230 due to the fact i wasnt paying $150 for a piece of plastic
call a BMW dealer and talk to either your salesman or parts. ask them if they can run your VIN to see if it is prewired for a CD changer (assuming you don't see the wiring in the rear compartment). all they will need is the last 7 digits of the VIN.
BMW does sell an IPOD controller, but i think DICE makes a better one. check them out here:
