p0640 appears to be invalid code.
p1640 shows to be quad driver fault. Does the vehicle run ok? I'm not sure I can troubleshoot?
Usually with older vehicles, you could damage a new computer or quad driver w/o proper testing of the appropriate wiring circuits and components.
Don't replace anything w/o proper testing of all components, involved.
quad driver A fault ECM module have input and ouput, quad driver are there to activate a solenoid or relay quad driver A drive a few of those output example quad driver A control canister purge solenoid and the solenoid is defect . the quad driver will kick off until you change the solenoid there is two kind of driver 1984 to .......one will reset if trouble is repair the other one is the ecm module itself have to be change after is repair .....(quad driver act has a driver or big fuse)
Change the transmission fluid and filter. Most vehicle owners do not do this enough (if at all!) and do not realize its importance. Fluid becomes gummed up which dramatically affects shift points and throttle valve performance. With your severity, I would suggest a full backflush by a mechanic.
Yes, the engine mounts and bell housings are the same.
The swap should be straight forward, however be sure to swap all the vaccum controls and emission system from the 2.6L.
Are you still need help with your Olds
Do you still need help
I'm sorry what is the problem with your olds
what is the brand and model you have
What is your question
