Question about RCA Lyra RD1080 MP3 Player
No Sound I turn it on and the volume level shows its up to the max but after a few seconds it quickly goes to 0 for volume level. I can still read the screen and battery connections are all fine. I just have no sound via headphones or car system. Replace or fix?
  • 85 Answers
If you get sound AT ALL then your button is stuck.
Posted on Nov 13, 2007
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Solution for jvc ca-uxep25
could be a damaged volume contact switch. the dome on them can crack or split connecting the switch all the time.... or it could be a faulty IR board. IR controller on the bard has gone at some point used to get it on old cheap tv's in the erly 90's
May 16, 2013 | Android Apps
Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Mar 04, 2010 | Sony STR-DE875 Receiver
Volume will not maintain level
To fix the problem, I reset the iPod.
Feb 13, 2009 | Apple iPod MA446LL/A MP3 Player
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
The sound is too low
i have the same thing...did u ever find a solution?
Aug 28, 2008 | Sony MHC-GX450 CD Shelf System
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Eltax avr-200 no sound
Eltax AVR-200 will start up in protection mode if the amplifer went into protection mode due to high volume before it was turned OFF and it will start at the same volume level as it had before power OFF.
To correct this you must shift to another input without signal, then turn the volume down before it goes into protection mode again.
Jan 12, 2008 | Audio Players & Recorders
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
RCA Lyra RD1080 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
