Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture When I turn my tv on there is sound but no picture and the standby light just continues blinking. Help!
  • jamesw1 Nov 13, 2007
    sixteen flashes then pause? I have been told by the repair man that the tube has gone. Count the flashes, they tell you what is wrong.
    Sergeant:
    Champion:
  • 346 Answers
Video processor malfunction
Posted on Dec 22, 2007
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Standby light continuously flashes with no picture or sound
count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Aug 06, 2009 | Sony KP-53HS10 TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light...
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Oct 20, 2008 | Televison & Video
Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Jun 28, 2008 | Sony KP-53HS10 TV
No picture, no sound, stand by timer light flashing
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
Jun 09, 2008 | Sony KV-32V40 32" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
