Question about Thermador 37 in. SGSX365 Gas Cooktop
Thermadore gas stove top - left 2 burners won't light
I have a Thermadore gas cook top model SGSX365ZW. I has 5, star burners. The left two burners (front and back) will not light. The igniter sparks, but gas does not appear to be getting through the burner to the igniting spark. What could be the problem. Getting desperate before Thanksgiving. Thanks.
  • 130 Answers
Re: Thermadore gas stove top - left 2 burners won't light - Thermador 37 in. SGSX365 Gas Cooktop Cooktops
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
0 characters
3 Points
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 29, 2010 | Thermador SGS36GS Gas Cooktop
Burners do not light consistently
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
Apr 18, 2010 | Whirlpool GLT3034 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Ignition does work - stove top doesn't light
Please provide model number so that I can tell you what to do for this unit.
Oct 29, 2008 | Thermador Cooktops
Thermadore cooktop SGCS365RS
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Jun 08, 2008 | Cooktops
Thermador 37 in. SGSX365 Gas Cooktop Logo
1,241 people viewed this question
Top Thermador Cooktops Experts
Barrett Palumbo
Barrett Palumbo
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
