Toshiba Satellite A215-S7437 PC Notebook
Problem for Toshiba Satellite A215-S7437 PC Notebook
The screen just goes blank. the blue lights on the
By tschmidt4226 on Jul 08, 2009
the screen just goes blank. the blue lights on the keyboard indicate the computer remains plugged into outlet, the on light is lit, but the ?processing? light is on...but nothing is happening. it is as if the computer is off. the fan will shut off, and no amount of button pushing changes things. the only way to get anything going again is to shut the computer off manually and then turn it back on. things act normal from there on for quite a while.
Clarification Request
Posted by efs_perpends on Jul 08, 2009
are you using vista?
Solution #1
posted on Jul 08, 2009
Not Rated)
efs_perpends
Rank: Guru  Toshiba Expert
Rating: 89%, 712 votes
This problem has been reported by other users of the same system, with the following workaround:
Click here. You will need to download and update the bios to correct this behavior. Before doing so, please make sure you have full backups on external media of all your data and any software installation files that you have downloaded from the net...Occasionally bios updates can cause a loss of system data, and in that event you could be required to reinstall the OS and start anew. This is not normally a consequence, but you should be forewarned..It is also a good idea to make a written record of your bios settings before you apply the update, in the event that some settings are changed by default you will be able to reconfigure the system after the new bios is installed.
Check the parts numbers carefully to be sure you download the correct bios update for YOUR system...
You might also find some useful information on the Toshiba support forums, by clicking here.
Be careful and follow the instructions from Toshiba for updating the bios and you shouldn't have any difficulty...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
ps there are a few other support bulletins for your laptop you might want to take a look at here.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A215-S7437
Questions and Unsolved Problems for Toshiba Satellite A215-S7437
Do you recommend Toshiba Satellite A215-S7437 PC Notebook?
Answer
Answer
stuck when boot on level 67. Dell L 610
Answer
i cannot activate bluetooth in packard bell easynote tj65 running windows 7
Answer
I have a aspire one netbook model no. kav60. I have both the pxe-e63 and pxe-m0f errors display when... (More)
Answer
http://www.bilgisayarhane.com aloo
Answer
the sound isn't working on my toshiba a215 7437
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A215-S7437...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
