The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
I just answered your question on the previous situation but here it is again. A GFCI receptacle placed in a circuit controls power to all remaining devices on that circuit. If the GFCI trips, anything after it shuts down. That is your situation. If your fridge keeps tripping the GFCI, it has a grounding problem. You should have your fridge checked out so that your family does not receive an electrical shock when contacting the fridge. Be safe.
You need to determine if it is experiencing a ground failure or a short. You can purchase an outlet tester at Lowes for a low price that will indicate if you have an open ground, a short etc. If the GFCI outlet is bad then replace it.
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
the stove should be on it's own outlet and not a gfi,also have you tried to plug anything else into that plug to see if it's the gfi that's bad?if it is the stove check for shorted wires,bad ignitor or something like that,if you plug it in and it pops right away it sounds like you have a direct short and have to pull off the back panel and check for a wire that's touching metal or a burn mark somewhere and send the model number off of the machine
first thing to do if it is continually tripping is to replace the gfci. they do go bad over time. Shut the breaker off to it. remove and note which wires go to which screw. if it gets wired wrong because going by memory. tis not fun trying to figure it out.
Best of luck
hope this helps and solves it. It should, if not call a tech for the fridge. or post model and make and we can go from there.
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
