Washing Machines Logo
p
peter emery Posted on Mar 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a WIXXL 146 that ist heating water, no fault codes are showing in the lamps, machine otherwise fine. Is the easiest way a resistance check on the element?
Gil Shultz
Level 3:
  • Washing Mach... Master 3,464 Answers
  • Posted on Mar 02, 2015
Gil Shultz
Level 3:
Answers
3464
Questions
Helped
731790
Points
11104
Try a volt meter first, if you are getting voltage the next best thing is a clamp amp meter. Resistance will be probably less then 15 ohms (guesing). I have added a link for the manual.
Indesit WIXXL 146 Instruction Booklet
http://www.manuals365.com/swf/indesit/wixxl146-gb-hires.html?page=12
My washer keeps saying err bush hw60_1460d
Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
My LG has an ie error that persists even when the valves and inlets have been checked, the machine shuts down while filling with wate. Had the machine less than 3 years, how do I fix this?
it could be the heating element, if the heating element is damaged the pcb will cut the power. as its detected a fault. the element has a resistance if it goes up or down in resistance the pcb detects this as a fault. you can test this by removing the wire to the heater element, it will fill up with water then but when it comes to heating water it will shut of as a fault. and show a code.
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
I am having a problem with my Whirlpool AWO/D 43135 washing machine.It stops when starting any program and shows error code F23.What should I do?
The fault F23 could be linked to the water temperature not reaching the right temperature. If your model uses hot water inlet connection then check if your hot water unit is providing the correct inlet water temperature. Otherwise it is likely the temperature sensor or heater element maybe failing.
See description
HEATER FAILURE
If the temperature increase during the first 40 minutes is less than 86degF (30degC).
2. Check connection to water heater.
4. Check the water temperature sensor and connection to it.
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
1helpful
TE code wm2688hnm
proceed with common sense and logically, fix it use the Vom or DVOM .God bless you
For this error code you need to check both the water heater or element and thermistor, basically the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
  • Check water heating element
  • Check heater for contunuity,
  • Check steam heater for continuity usually
  • Check thermistor or temperature sensor
  • Check the thermistor resistance,
  • Check wiring to water heating element
  • Check connections to water heating element and temperature sensor
3helpful
INDESIT WIXXL 146 washing machine ( please help
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
10helpful
3answers
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Top Washing Machines Experts
john h
