HP LaserJet 3015 All-In-One Printer Logo
A
Anonymous Posted on Mar 02, 2015
Error code 358 mean?
When I try to send a fax i get comm eror 358, what does it mean?
William Alequin
Level 3:
  • Master 932 Answers
  • Posted on Mar 02, 2015
William Alequin
Master
Level 3:
Answers
932
Questions
0
Helped
201593
Points
2855
Please, click on the link, it will take you to the HP support center in which explain the problem and gives you a solution also.
http://support.hp.com/us-en/document/buu02549
Just scroll the page down until you find the error code. Best of luck.
A
Anonymous
From HP: "The remote user pressed the Stop key, causing the session to be terminated." Meaning the problem is at the location of the fax you are sending TO. Call them, and ask them to confirm that their fax device is ready and able to receive.
1helpful
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
1helpful
EROR 420
The error that you are receiving means that the machine goes to receiving mode, but receives no command from the transmitting side. The problem is not with your machine, but from the party sending you the fax.
1. Remote side mis-dial.
2. Check with the other party.
I am using the PE 16 & suddenly I get a comm. error when I try sending faxes, both using the automatic dialling or dialling manually - I tried unplugging from the elect. & the phone line &...
comm error could mean numerous things is the phone line cord your using new? do you hear it dailing or a dail tone? are you on dsl as far is Internet these use filters that can mess with communication.Does it use standard dailup to send faxes
2helpful
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
5helpful
WHAT DOES FAX ERROR CODE 358 MEAN THANK YOU
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
2helpful
2answers
Comm error 634
Receiving fax never picked.
Fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
2helpful
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
k24674
Grand Canyon Tech
Grand Canyon Tech
