Question about GoVideo Go Video DVD/VCR Combo
I have a go video dvd/vcr combo. The vcr makes a hissing noise when played. Also shows poor tracking. Is it worth fixing?
    Scholar:
    New Friend:
  • 56 Answers
Start off with using a vcr tape cleaner make sure you read instructions some are just a brush while some others cleaners have a small liquid cleaner to add to it after using cleaner do not worry about rewinding it until another day you may need it.you can also try switching the progressive scan off if being used.If its eating tapes the tensioner could be loose or wore out or the locking mechanism is not working properly when tape is inserted.If you are not experienced in this field I recommend letting a shop look at it if so cleaning it is about the only thing you do also try opening the vcr tape bay door taking a deep breath and blow inside it without a tape in it do this several times it may just be dust and you can try unplugging it for 10 minutes to reset the device to see if its a stuck communication glitch in the board for the head motors.I hope one of these three basic tricks helps you.
Posted on Mar 05, 2015
SOURCE:
How to fix my Toshiba DVR620's Poor VHS Quality?
The flying head is dirty. Open the unit and clean it with isopropylic alcohol or similar with a smooth cloth like the same used to glass clean.
Aug 29, 2014 | Toshiba DVR620 DVD Recorder/VCR
How do i adjust the tracking using a remote
the TRACKING IN VIDEO VCR , you can adjust from your remote control, you must identify by reading your instruc, manual download for free. go to www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jul 13, 2012 | GoVideo Go Video DVD/VCR Combo
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
My toshiba tv/vcr/dvd combo wont play dvd's anymore. Is this worth getting fixed? Is there a warrenty for the dvd ? Or should I just buy a new tv and dvd ?
No. Usually it will cost you more money than gettting it fixed. If I make a suggestion. I would get a stand alone dvd, because if the dvd goes out in the television then the tv may not work.
Dec 26, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
VHS output is fuzzy
i think its the tracking adjustments.
May 27, 2009 | Sanyo HV-DX2E DVD Player/VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
EWD2004
Service is needed on the VCR as it comes from the factory with a feature called auto tracking...accordianman
Dec 25, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
GoVideo Go Video DVD/VCR Combo Logo
74 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
