SOURCE: 2004 dodge neon has high rpms and no speed
ok i just replaced mine to but you have to make sure that you replace the throwout bearing(correctly)
if this does not happen it is like the clutch is engaged partially all the time and another thing is that make sure no oil is in the clutch pack. i replaced my main engine seal while i had it apart because it was tossing oil into the clutch area.
Good Luck
the check engine light means that a code has been set. the code will reference a faulty system that must be diagnosed and repaired. sorry for the vagueness, but there are e gads of codes that can cause the rough idling
most aftermarket parts places will scan the car for free. this will give you an idea of where to start.
SOURCE: Idle seems a bit high. Need to know how to adjust and what RPM
There are a couple of things that come to mind. One is make sure the EGR Valve and intake manifold are not carboned up. I normally have to clean them every 60 to 80,000 miles. It will actually close up with Carbon and restrict air flow and make the EGR valve malfunction.
Secondly, the diesel pump may just have a lot of wear and it is putting out too much fuel at idle. The only way this can be checked is by the dealer with a VW specific scan tool such as VAG-COM. With this tool, you can go in and look at the the pump timing and start injection quantity.
I have the start injection quantity many times but you have to have the software and login to get the readings. Most dealers will not do this but would rather sell you a pump if it is off.
Remove the hose from the intake where it connects to the EGR valve and look at the inside with a flashlight. See how much carbon is accumulated. This may not solve this problem but will help with starting and performance issues if corrected.
Good luck and hope this helps. To adjust the Idle, it needs to be programed in to the ECM so i am thinking that it's a Carbon issues that is restricting the air flow which the ECM is compensating to keep the engine from stalling.
SOURCE: 2004 jeep grand cherokee idling problem. Revs motor 200 to 500 rpms higher while driving.
I had the exact same problem on my 04 GC. I put some Techron Concentrate Plus Fuel System Cleaner in from Wal-Mart and it seemed to fix the problems right away. Let me know.
SOURCE: sluggish acceleration. High RPM, High Oil Pressure
I hope I'm wrong but I think your torque converter is failing. Sorry, Gary
