1 spark plug is stuck, with socket in it. Do i need a spark plug gap tool, to measure gap?
If your can see the difference between .020 (20 thousands) and .025 (25 thousandths) of an inch than you may not need a gap tool.
A $3 spark plug gap tool is a must, you can get it at any auto parts store. Also if your spark plug is stuck in the socket, get a new socket and spark plug, but if you need it now take the socket wrench off the socket and place the socket in a vice. Then with the biggest screwdriver that will fit in the socket wrench hole, place the screw driver tip on the top of the spark plug stuck in the socket and hit the other end of the screw driver with a hammer until the spark plug comes out...... get a bigger hammer. note: the old spark plug may not survive.
Testimonial: "Thanks alot, could only happen to me. Makes sense though, thanks Mr Murphy"
A feeler gauge or spark plug gap tool is the only way.
Testimonial: "Got it, thought i,d ask as lost mine. Thanks for help. all best"
If you're replacing the spark plugs in your car
engine, you'll need to set the gap before reseating the
spark plug. The gap is the distance electricity arcs between the ground
electrode and center electrode. The gap must be set correctly to ensure
maximum performance. Here's how to set the gap of a spark plug.
