Question about Toshiba Satellite A135-S2276 Notebook
Replacement of Toshiba Satellite A135-4427 screen
How do you dis-assemble the cover to replace the screen.
  • Ric Casto
    Ric Casto Nov 13, 2007
    Are their screws that allow access to disassemble the lid itself, that allows for replacing just the screen and not the whole lid?
  • First, purchase your replacement LCD display for your exact model of Toshiba A135. I found mine for about $110 with shipping.
  • There are five screws hidden beneath rubber bumpers around the screen. Carefully use a small flat screwdriver to remove the pencil eraser sized rubber bumpers - one at each corner, with the fifth at the top center. Make sure you carefully remove the sticky stuff they used to adhere the bumper to the screw as well. Set these carefully aside.
  • Remove the five screws and set them aside.
  • Gently press down at the inside plastic frame until it pops out slightly. Gently press towards the center of the screen at the sides of the inside plastic frame until it pops out.
  • Carefully separate the front and back plastic shell around the screen. Set the front plastic frame aside. You may need to loosen some of the white tape used to keep wires attached to the rear plastic shell. Gently lower the rear plastic shell away from the LCD, but leave as many wires attached as possible.
  • On the back of the LCD there is a large cable. Carefully pull up the tape that holds this cable in place and pull the cable down to remove it. You will also have another piece of white tape on the back of the LCD to peel back. The tape is important - don't tear it or get your fingers in it to remove its stick!
  • At one end you will see a set of a few wires plugged into a piece still attached to the rear plastic shell. Unplug this.
  • No wires should still be plugged into the LCD anywhere at this point.
  • Around the LCD there are six small screws. Remove these and set them aside. You now have now removed the old LCD.
  • Reverse this process to re-assemble.
  • You may want to use some blue LockTite (which can be found at hardware stores) for the screws as you replace them. Additionally, you might need a little rubber cement to re-attach the rubber bumpers at the last step. If you do not re-attach these bumpers, your screen will quickly become scratched by your keyboard touching it when the lid is closed.
Posted on Apr 09, 2010
  • 93 Answers
With most toshibas the part above the keyboard is removed
then remove the shoulder parts that cover the hindges
this will give you access to the main screws that hold in the
thee will be a small plug into the main board for the screen to plug into
this make of lap top does not need to be completely disassembled
let me know how you get on
please rate me fair !
Posted on Nov 13, 2007
Posted on Oct 26, 2008
How to replace keyboard
This site has the dis-assembly instructions for many Toshiba laptops,
Oct 13, 2013 | Toshiba Satellite A135-S2276 Notebook
Broken Laptop Screen: Toshiba Satellite c670-165
As in this model?
The Display Assembly is laid back to a point, that you can access the two bottom screws. Isn't a direct 90 degree position with the screwdriver. More like 60 degrees.
Then the Top Cover (Palm Rest Cover) has to be removed, in order to access.
Don't forget to remove ALL power. AC adapter and Battery.
Jan 13, 2013 | Toshiba Computers & Internet
Where is the cmos battery on toshiba satellite laptops
it is inside in the computer, need to dis-assemble it and you will find on motherboard
Jan 08, 2013 | Toshiba Satellite P305D-S8900 Notebook
Cover locks on laptop need replacement
You maybe able to get a replacement part from one of these WEB sitesfor your model laptop.
Sep 04, 2012 | Toshiba Satellite A215-S4807 Notebook
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my...
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site.
Hope this works!
Apr 11, 2011 | Toshiba Satellite A105 Notebook
I need to replace the LCD screen on my Toshiba Satellite P305D-S8828. Can you provide step by step guide with photos or a video?
Replacing LCD is not a big deal. Just follow these steps:-
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out.
6. Disconnect the wires. One wire goes to the backlight, while the other goes to the video card.
7.Use exact serial no. LCD for exact replacement.
8. Connect the video wire and the backlight wireand affix it using the tape that held the original in place.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Hope they work for you. All the best
Dec 09, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
Need to remove cpu fan
STEP 1Always start laptop dis assembly with removing the battery.
Remove six screws securing the hard drive cover and the heatsink covers.
Remove one screw securing the hard drive to the laptop base.
Disconnect the hard drive and remove it from the hard drive bay.
Remove three screws securing the CPU heatsink to the system board.
Carefully lift off the heatsink off the laptop CPU.
The heatsink is 100% clogged with lint.
If your heatsink is clogged, clean the heatsink with a canned air to prevent your laptop from overheating.
Mar 08, 2010 | Toshiba Satellite A45-S150 Notebook
Toshiba Satellite Pro A40 Can't find RAM memory
The memory is located under the keyboard
Remove batt and cables
open screen
pop out the rectangular panel surrounding the on off buttons
remove the 3 screws and lift up the keyboard to access the memory
Dont ask me why they made it this complicated
Manual can be got here
Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Replace phone plug for Toshiba Satellite M55-S141
Go to type laptop repair and look for and they have a diaigram for toshiba laptop dis assemble
Mar 20, 2009 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
1,265 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
