Your gas tank has a float inside that is kart if tne. Fuel. Pump assembly that indicates the amount of fuel in the tank..it sends a message to the gauge...sounds like the float is sticking when the gas is sloshing around when moving..causing a false read being sent to the gauge. Most times the tank has to be removed to replace..good luck..
I believe this is because of the trend toward plastic gas tanks or cheaper metal tanks. In the past they put baffles in the tank to reduce the sloshing around the float in the tank. Without these baffles the gas moves around like waves on the beach.
